Best speaker setup
Hi!
I'm new here, I would like to choose the best setup for my room.
He has 11 feet x 16 feet, but it is integrated with another room.
I want buy all polk speakers and I believe that the 5.1.2 setup is ok.
2 S20 speakers
1 S35 or S30 (what is better for my room?)
2 Atmos speakers (what use RC80i or v60?)
2 surround speakers (what choose?)
1 sub (what choose? HTS10?)
Thanks for any help.
Regards,
Cristiano
  • FestYboyFestYboy Posts: 2,884
    Personally, I'd flip the room 180*. Better front speaker placement can be realised without the windows to hinder it. It also allows more of the larger room n general to view the screen.
  • Tony MTony M Posts: 6,286
    What @FestYboy said...100%.
  • mrlorenmrloren Posts: 1,527
    What AVR are you going to be using?
    V60 over the RC80, vanishing looks a lot better
    S30 for the center, more full sounding if you can fit it.
    Sub look for SVS or HSU, if you can't get them where you are then the HTS is ok.
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • steveinazsteveinaz Posts: 18,400
    Anytime you have a couch against a wall, bass is gonna be wonky.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; Belden 1694A Dig Coax | AC Power: Panamax M5300-PM
  • Airplay355Airplay355 Posts: 4,258
    What's between the plants on the rightmost wall?
  • Hey guys. Thanks for replying. Sorry my delay in answer you, because it was a holiday here in Brazil.
    I personally prefer the other room too, but like in the picture the space is more visible.
    Between the plants it is a wood sideboard.
    The receiver probably will be an Onkyo TX-NR787.
    I will take a look in the SVS and HSU subwoofers, but i'm looking for a good budget woofer.
    Thanks again!
    edited November 4
    I'm not saying trade space for space, I'm saying flip your viewing room area 180 so the couch sits where the tv is in the picture and visa versa.
    Edit for auto correct
    edited November 4
    I agree to flip your room. Reflection's from windows suck, I found it to add brightness to the sound.
    AVR, I would get a Denon, Marantz, Yamaha or even Sony over an Onkyo.
    If you can get either HSU or SVS subs they are a step up from the HTS. I have heard the HTS subs are better than previous Polk subs.
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
  • Thanks again!
    Now I understood. I will check the possibility to flip the room, the main question is that all instalation (power, network, etc) is in the other wall.
    About the AVR I will look for another brand, thanks by the advise.
Howdy, Stranger!
