Shameless Plug !!!!!!!!!
gimpod
gimpod Posts: 1,793
edited October 2018 in For Sale (FS) Classifieds
Upgrade your 4th & 5th Gen SDA boards and crossovers Here. ;)
Check with David (@westmassguy) at DHS Speaker Service.
  • verb
    verb Posts: 10,176
    Tony does some excellent work! Great boards!
  • vmaxer
    vmaxer Posts: 5,116
    DSkip wrote: »
    Nothing to be shameful of here. You provide this community with a great service and product.
    Exactly
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • voltz
    voltz Posts: 5,384
    Tony
    your boards are so special to use SDA lovers that it need to be out in the open so others can see how much better these are then trying to cram all those newer caps into a smaller board that you have to first un-soldered to use again!
    The newer better caps are just so much bigger now that these boards are AWESOME!!!!
  • gimpod
    gimpod Posts: 1,793
    Thank you guys! :smile:
  • verb
    verb Posts: 10,176
    And, too add, we’re glad you’re back!
    nooshinjohn Posts: 25,033
  • headrott
    headrott Posts: 5,484
    Tony's boards are top notch. Buy them for your 4th or 5th gen. SDA's without hesitation. I used them in my 2B's, 3.1TL's, and 2.3TL's, and would use them again without hesitation.
    pitdogg2 Posts: 24,471
    BEST NON-POLK PRODUCT EVER!!!!
  • headrott wrote: »
    are they ok for gen 1 SRS's?
  • scubalab
    scubalab Posts: 3,101
    Toolfan66 wrote: »
    ... Good one, Larry! B)
  • gimpod
    gimpod Posts: 1,793
    edited October 2018
    NO 4th & 5th Gen Single Board Style SDA/SDA SRS ie.. SDA 2B/CRS+/TL MOD (1987+), SDA 1C, SDA SRS 2 (1987 Pin/Blade I.C.), SDA SRS 3.1TL, SDA SRS 2.3, SDA SRS 2.3TL, SDA SRS 1.2, SDA SRS 1.2TL.
    And yes I know bad timing.
  • jdjohn
    jdjohn Posts: 2,987
    No shame in that game B)
    Sadly, my newest project pair are 1Bs, so will have to play Tetris with the caps when that time comes.
