RM6750 with Pioneer VSX-1131
sharabhi
Can someone direct me on how to properly connect my sub? I have the polk RM6750 set. On the manual it shows on Page 6 figure 6 here: http://www.specsserver.com/CACHE/FILE26574.PDF
But does that mean i don't use the subwoofer port/cable as it shows on the receiver's manual?
Any additional setting to be aware of if I setup as the polk manual suggests?
I started with the RM6750 set 10+ years ago and it lasted me all of 5 minutes... Sounded awful in my room. Unless you have a very small room, you can do so much better than this. Actually, I wouldn't even recommend it for any size room. If small speakers are needed, try the Polk Blackstones.
