Resistors for Tweeters
I’m trying different value Mills 12 watt resistors to bring down the high end of my Magnepan MG 3.6s. Does anyone have recommendations for other more expensive brands that I should get once I decide on a value that works best? I’m looking at Duelund and Path, but I’m sure there are others to consider.
Thorens TD-160C; Sumiko Talisman S; Jolida JD9; Marantz CD-53; Micromega Mydac
Joule-Electra LA-100; Balanced Power Technology AC conditioner;
Odyssey Khartago monos (with most factory upgrades); Magnepan MG 3.6R
  • F1nutF1nut Posts: 40,369
    Maggies, IME are not known for having a hot top end. Anyway, I'd stick with the Mills.
  • maxwardmaxward Posts: 147
    I am stuck with a wall of windows behind the speakers. Some DIY panels helped a lot, but there is still a bit too much treble energy on many recordings. Well-recorded LPs are an exception, so maybe I need a better DAC.
    Ten feet, so probably not a ceiling issue.
    I might try it.
    maxward wrote: »
    So, the issue only raises its ugly head when playing CD's?
    I am generally more aware of the issue when I listen to CDs versus LPs. Lazy guy that I am, CDs are mostly what I play.
    In that case, your comment about needing a new DAC is likely correct.
  • DSkipDSkip Posts: 14,864
    What cables do you use - speaker, ic, power...?
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Speaker cables and amp and preamp power cords are MAC (my audio cables) made by Steve Hallick, who I believe is now out of business. Reviews can be found online. Other power cords are Pangea except turntable, which is captive. Interconnects are mostly Straightwire Musicable II or better. Digital is MIT. Thanks, @DSkip.
    I have been considering either a Schiit Bifrost or Gungnir multibit as a replacement for my current DAC. After reading @DSkip and others, the North Star Design Intenso looks very promising for a price that splits the difference. Has anyone heard these back-to-back?
Howdy, Stranger!
