Magnifi Max SR surround sound chromecast
FrankfolscheFrankfolsche Posts: 3
edited September 23 in Customer Service
I just can't seem to get Dolby digital to work from a chromcast plugged in through hdmi in the soundbar.
I've tried this using netflix, the nexflix app does not recognize that the soundbar supports dolby digital. But when i connect it to my other chromecast on a onkyo 5.1 receiver it does recognize it. This makes me believe that the problem lies with the soundbar.
To illustrate this i made a video, showing the nextflix app displaying 5.1 when connected to my living room setup (onkyo receiver) and not showing the 5.1 symbol connected to my bedroom setup (magnifi max sr).
https://1drv.ms/v/s!An77HnLC2SaLhJAoc3b93z1GZdd89A
How every i'm able to get the soundbar to play dolby digital through my laptop using the win 10 netflix app
Why are the chromecast netlix and the magnifi max SR not playing nicely together..
Does anyone had any tips.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,614
    Hello,
    Let me send this to an engineer at Polk for help.
    Cheers, Ken
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Hello,
    Cheers, Ken
    Hi Kenneth,
    Did you get anything back? I'm thinking about buying a Magnifi mini too but only if I can play 5.1 through it.
    Frank
    No reply yet.
    Hello,
    I received this message:
    "My first question would be what color is the light on the front of the Magnifi Max? It should be green for Dolby. Nextflix doesn’t pass anything but Dolby Digital unless specified manually in Netflix."
  • Hi,
    I received feedback from polk customer support.
    "MagnifiMax will support DD (5.1) and DTS
    Netflix will offer only DD+ and Stereo Sound with their films
    As DD+ is not supported by MagnifiMax only Stereo sound is selectable in Netflix app (cromecast selected as playback unit and connected to MagnifiMax)"
    So it means the Magnifi series cannot be used with Netflix using surround sound. (unless you use a device that can decode DD+ to DD this also means that need to pay to dolby so no cheap device available.)
    I think this is very disappointing of Polk especially because DD+ specification is about 10 years old now and even my 6 year old onkyo receiver supports it.
    Looking online the best suggestion i've seen is to buy a new receiver that does support DD+.
  • rooftop59rooftop59 Posts: 4,589
    edited September 27
    That stinks, but the problem is also with the chromecast. My MUCH older amazon fire tv (first gen) allows one to pass through whatever sound codex the app is sending through to the receiver (such as DD+), or to limit it to DD 5.1 or stereo. Even my one year old Samsung smart tv (which has 4k apps that work very well) can only pass through 5.1, so it is either downconverting DD+ from netflix or netflix has adjusted the app for Samsung TVs. So, if your chromecast offered this downconvert option (or if you buy a roku or fire tv) you can choose DD 5.1, and that would be much cheaper than new receiver or soundbar. Just make sure that whatever streaming device you purchase offers that option.
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio Nova Integrated; Bryson BPD-1; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; LG UP870 4K BDP
    Master Bedroom
    Marantz SR-5007; Peachtree Audio NovaPre; Audiosource Amp Two, PSB Imagine B, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, Squeezebox Touch
    A further explanation:
    "My guess is that Netflix is playing Dolby Digital Plus, not just Dolby Digital. We do not support Dolby Digital Plus at this time, although that may change in the future. If this is the issue, he can go to settings in Netflix and tell it to output Dolby Digital and not DD+."
    Polk is going to duplicate this issue and confirm what you are experiencing.
Howdy, Stranger!
