Joule Electra LA-100 Phase Inversion
Can someone please explain to me the functional result of the LA 100s phase inversion described below? It doesn’t reverse the left and right channels, does it?
I ask because I just discovered, strangely, that my left and right channels are indeed reversed. It’s probably the speaker cables that are crossed in the crawlspace under the listening room, but as that’s not easily accessible I can’t really check.
Thanks.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
  • erniejade
    erniejade Posts: 6,315
    It changes what’s positive and negative not the actual L or R.
    heiney9 Posts: 25,082
    The reason your speakers are reversed is explained in the very 1st sentence by the term "is phase inverting". You can do as described in the following sentences if the pre-amps doesn't include a "phase" switch on the pre.
    Do a Google search for more info as camps are divided about this issue.
    edited September 2018
    Also recording engineer's use phase inversion as a production technique. So even if your system is in absolute phase for one recording, it may not be for another. It's a sticky subject that can be debated on both sides.
    This link might help. It's about mixing audio, but the principles of audio phase are the same.
    https://www.uaudio.com/blog/understanding-audio-phase/
  • stretchl
    stretchl Posts: 1,334
    erniejade wrote: »
    Thanks. I think this answers my question. I just need to switch the right and left cable to get things back in their proper order.
    Thanks also to @heiney9.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • lightman1
    lightman1 Posts: 10,776
    It's not switching left and right "channels"...
    It's reversing the phase of the + and - on the input/output of each channel.
    I ran into this with my Rogue 66 pre amp. A suggestion is to switch the polarity at the speakers. I have done it either way and noticed no discernable difference in sound quality.
    Hope this clears that up....
    F1nut Posts: 49,806
    heiney9 wrote: »
    ^ That is incorrect ^
    Russ nailed it........
    I didn't say "channels" it's the positive and negative on ONE channel being reversed. And yes what I copied from the onwer's manual is correct. If it inverts phase and your amp doesn't invert phase then the signal is out of phase.
    F1nut Posts: 49,806
    I see what you were trying to say now Brock. It came off like you were saying the reason his left channel is playing in his right and vice versa was due to the inverted phase.
  • lightman1
    Settle down and know your role, Brock....
    treitz3 Posts: 18,342
    Shut up Russ.
  • vcwatkins
    vcwatkins Posts: 1,993
    Give the +/- switch a try. Helped in my case. Not huge, but definitely discernible.
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • kharp1
    kharp1 Posts: 3,453
    I reverse the speaker connections on the amp side. Without this my sound was very spatial yet had n "weight" and "something" was missing.
    tonyb Posts: 32,906
    Hows that Joule burning in Kerry ?
    You haven't bought anything in like a week, getting that itch ? :)
