Wiring
I have a set of RTi10 speakers which have 2 sets of speaker connections. I am hooking them up with a sub woofer. If I use the upper connectors it sounds like an old transistor radio and if I use the lower, I lose all of my high end. I recall when I first bought them years ago there was some form of copper connector between the upper and lower connections. Do I need to find a new set of these in order for the speakers to work correctly or am I perhaps doing something else wrong? I know this seems a pretty basic question but appreciate any help.
  • F1nutF1nut Posts: 40,369
    You need a jumper between each top and bottom set of binding posts. Use high quality speaker cable with high quality terminals.
    Here's an example pulled off the Net.
  • mlistens03mlistens03 Posts: 2,104
    If you don’t have access to high quality wires, any wire will work, but a better quality cable will certainly be better.
    Not Tom, or Trey, or Jim
    In a few days, it will be...
    NAD C352
    Monitor Audio Radius R90’s/Polk SDA CRS/Mission Freedom 770 IV
    BJC speaker cables, generic RCA’s
    Technics SL3200 turntable and a Shure M97xE phono cartridge
    Velodyne VA-907 subwoofer
    Lafayette LR-1100 acting as a tuner
    TCC-TC750 phono stage
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • BarryeaBarryea Posts: 2
    Thank you very much, I kind of suspected I needed to somehow bridge them.
Howdy, Stranger!
