Streaming for Dummies
OK, I admit it when it comes to streaming I am a dummy.
I have a Win10 computer with a USB connected DAC. I wish is to bypass Windows and send a bit-perfect stream to the DAC.
For a quick test I downloaded Spotify. I set it to use the computer but I am getting audio out of the TV and not the DAC.
What am I missing?
Mojo Audio Joule v5>>Quantum Byte w/JRiver 24 and Fidelizer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts PA-6 Elite Mod)>>
SRS 2.3TL (Fully Modified)...SDA-1A (Fully Modified with Dimensional Tweeter Delete)
1KVA Dreadnought
Marantz SA 8005
  • mlistens03mlistens03 Posts: 2,118
    Ok, so I don't have good answer for what's wrong, but i can give you an idea to try and fix it...
    So you are using a Win10 PC with a TV, correct? Is this HDMI? Go into the TV's menu, and look for the "sound" option. Under sound, there will most likely be an option to turn off the internal speakers. Since the input is HDMI, the TV should communicate with the PC so that the PC doesn't send audio through the HDMI ports. I think, once again I could be totally wrong. Then, the PC will look for somewhere else to send audio, and in theory find your USB DAC. If it doesn't, then, there are audio settings in Windows 10 that you can look at, to see what's going on, and change settings if needed. I haven't ever been into the audio settings on Windows 10, so I can't help you there. One more time, I say I'm not sure on any of this, but i believe it to be the case.
    If your not using HDMI, this may still work, but I doubt that it would.
    Not Tom, or Trey, or Jim
    NAD C352
    Monitor Audio Radius R90’s/Polk SDA CRS/Mission Freedom 770 IV
    BJC speaker cables, generic RCA’s, one homemade power cable, because that’s going to do any good with the rest of the generic ones.
    Technics SL3200 turntable and a Shure M97xE phono cartridge
    Velodyne VA-907 subwoofer
    Lafayette LR-1100 acting as a tuner and phono.
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • ClipdatClipdat Posts: 4,712
    Click the start menu, type sound, click on it and then take a screenshot of that window.
    Got Dayens?
  • haimochaimoc Posts: 1,016
    edited September 5
    Probably, Spotify app does not have interface to Windows Audio Session API (WASAPI) or ASIO to send bitstream to the USB DAC. If you have your own audio files, you can play them with Foobar2000 (free) or licensed SW such JRiver to send bitstream to the USB DAC.
  • rooftop59rooftop59 Posts: 4,589
    haimoc wrote: »
    Tidal will also take control of the output device/Dac. It’s not free, but the same quality - 320mbps - costs the same as Spotify premium.
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio Nova Integrated; Bryson BPD-1; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; LG UP870 4K BDP
    Master Bedroom
    Marantz SR-5007; Peachtree Audio NovaPre; Audiosource Amp Two, PSB Imagine B, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, Squeezebox Touch
    edited September 5
    rooftop59 wrote: »
    haimoc wrote: »
    It is good to know that. Thanks. I also have Foobar2k to work with Linux's PulseAudio/Jack which is similar like Windows WASAPI/ASIO, too.
    And the jump from Spotify to tidal is like, well, the jump from Spotify to cds. Well worth it imho...Of course that is only the $20 a month version...
    HT Rig:
    Master Bedroom
  • machonemachone Posts: 1,004
    Clipdat wrote: »
    Thanks Clipdat,
    The driver for the dac was not set as the default. Everything related to Windows is grayed out so I assume (hopefully) that it may be sending a "bit-perfect" stream to the DAC.
    Is this correct?
    1KVA Dreadnought
    Marantz SA 8005
  • Sounds like you’re good to go.
    machone wrote: »
    Thanks Clipdat,
    Is this correct?
    The ability for it to be "bit perfect" relies on the software and output plugin that you're using. I know the Tidal desktop client can gain exclusive control of the DAC and bypass the Windows mixer, I'm not familiar if the Spotify client can do the same as I've never tried it.
    Got Dayens?
  • jeremymarcinkojeremymarcinko Posts: 3,189
    edited September 6
    Is there such a thing as a bit perfect mp3? I guess there could be, I mean, you wouldn’t want a lossier lossy file from Spotify. I guess.
    rooftop59 wrote: »
    haimoc wrote: »
    I just gave TIDAL a try, and it works great with the USB DAC.. :)
  • codycatalistcodycatalist Posts: 1,615
    I'M NOT A DUMMY YOU'RE A DUMMY...just kidding I can be pretty dumb.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
Howdy, Stranger!
