HELP! Needed Inductor!
Anyone know of someone who has parted out a SRS 2.3 or??? And may still have the big 16.8 mH inductor? While restoring mine my dog got ahold of my old crossover and chewed it up. Dog gone now... But speaker pops in and out. Im sure its the inductor.
Yes I've spoken to Dave. He said I'm fu... Out of luck.
Thanks all!
SDA 1C's
B&K Reference 50 Pre
B&K M200 Sonata Monoblocks
Cambridge Audio DVD 99
  • mlistens03mlistens03 Posts: 2,104
    Animals that eat audio gear disappear quickly...
    You could possibly get a complete XO from a parted out set on eBay.
    Not Tom, or Trey, or Jim
    In a few days, it will be...
    NAD C352
    Monitor Audio Radius R90’s/Polk SDA CRS/Mission Freedom 770 IV
    BJC speaker cables, generic RCA’s
    Technics SL3200 turntable and a Shure M97xE phono cartridge
    Velodyne VA-907 subwoofer
    Lafayette LR-1100 acting as a tuner
    TCC-TC750 phono stage
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • FestYboyFestYboy Posts: 2,761
    Not all is lost. There's really no reason why you can't build one to match the other channel. The hardest part is finding the correct gauge of coated wire.
  • audioluvraudioluvr Posts: 431
    FestYboy wrote: »
    Been watching ebag since it happened. No luck yet. I may have to do the rebuild but been busy with other things so...
    SDA 1C's
  • pitdogg2pitdogg2 Posts: 10,813
    Sounds to me an easy excuse to upgrade the inductors.
    Oh ok... Ill look into a couple new Jantzen ones. Probably really expensive and on backorder but hey!
    SDA 1C's
    audioluvr wrote: »
    Nope they are really reasonable. But not Jantzen. Erse 18mh then you will need to unwind some to get the value you need. I did however get all new inductors big ones like i said came from Erse all the others came from england hi-fi collective jantzen All in all pretty reasonable and all will need to be tested as sometimes they are not close to listed value so you will need to have someone do some work on them before install.
    Reach out to Dave
    https://www.hificollective.co.uk/components/inductors.html
    http://www.erseaudio.com/Products/SuperQCoils16Gauge/ESQ55-16-18000
Howdy, Stranger!
