Lost left channel in Outlaw RR2160
So we haven't used our 1-year-old Outlaw receiver for about 6 weeks b/c of summer trips, etc.
Enjoying a show tonight and come to realize the system (2 channel) doesn't sound balanced. Checked to find the left channel is out. Tried Opt and USB input, Left channel is out with both sources.
I checked banana plugs at both speakers and back of receiver and all are snug. Pulled speakers out and switched Right with Left and the problem shifted to the Right speaker, so my speaker isn't blown. Put speaker bananas back to original speaker and switched banana plugs at the back of the receiver. Again, no sound from Left channel.
We've had storms and I don't know there was a lightning strike, but I would assume the whole unit would be blown, not just one channel.
Is there anything I'm missing or any trouble shooting anyone can recommend?
Thanks in advance!
HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
  • txcoastal1txcoastal1 Posts: 9,894
    edited August 26
    Check to see if there is more than 1 fuse...slim chance, but???
  • Tony MTony M Posts: 6,010
    edited August 26
    Un-plug it.
    It is your receiver for sure. Great diagnosing the basics. ;)
    Disconnect everything and take the top off.
    Look for fuses. I've just fixed 2 receivers with blown fuses in the past 6 months.
    I was lucky I could reach the fuses and pull them out and look closer.
    It is so gratifying to replace a 1.00 fuse and make things right.
    I hope you can have a look inside it. It might be easy, maybe not. We don't know yet.
  • The manual says one internal fuse that is not serviceable by layman.
    Well that brings us to a repair facility. :/ It might be worth it though.
  • F1nutF1nut Posts: 40,365
    It's serviceable, their lawyers are simply covering their butts.
    That said, if there's only one fuse that isn't the problem as it wouldn't power up if the fuse is blown.
  • I powered off both standby power switch on front and main power on back. I did not unplug it though.
    None of the other items that are plugged into that outlet seem to have been affected.
    Thx again for all the suggestions.
  • I'll call Outlaw today to see if they have any suggestions and ask about shipping it back if necessary.
    Thanks for the fuse suggestions. I have a mid '90s Sony DA80ES that I found at a thrift store. Used it and really liked for a couple of years, it finally shut down and displayed "SERVICE." I'll pull the top and look for fuses and use it till I get the Outlaw running again.
    35 years ago I was occasionally replacing fuses in my Polk M7s.
    Thanks again!
  • mlistens03mlistens03 Posts: 2,101
    Could it be your speaker cable? Did you switch the cables on the speaker side or the amplifier side?
    Not Tom, or Trey, or Jim
    In a few days, it will be...
    NAD C352
    Monitor Audio Radius R90’s/Polk SDA CRS/Mission Freedom 770 IV
    BJC speaker cables, generic RCA’s
    Technics SL3200 turntable and a Shure M97xE phono cartridge
    Velodyne VA-907 subwoofer
    Lafayette LR-1100 acting as a tuner
    TCC-TC750 phono stage
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • mhardy6647mhardy6647 Posts: 18,951
    mlistens03 wrote: »
    Always keep Occam's Razor* in mind when troubleshooting :)
    That said, two other thoughts occasioned by this thread in toto.
    1) did the OP try all sources (i.e., to eliminate a source or cable from source to amplifier that was, shall we say, bjorked**)?
    2) does that receiver have a headphone jack? If so, does the audio from the jack have one or two channels?
    _______________________
  • Good call; I’ll try headphone and tape out when I get home.
  • I emailed Outlaw Audio today at 12:47PM and got a response by 1:24PM. Not too shabby.
    Ben from Outlaw said to confirm that other sources were also missing the left channel. So I tried the tuner and just got the right channel. Ben said to do a factory reset by pushing a series of buttons on the remote. Unit shut down as part of the reset process and when I powered both channels were firing. Chris Stapleton's been going since!
    Thanks for everyone's input.
  • la2vegasla2vegas Posts: 2,780
    Glad you dodged a bullet.
    Great customer service on Outlaws' part.
    Did Ben offer any insight on what might have caused this?
    2.3TL, 3.1TL, SDA 2B, SDA II, 7B, 7C, 7 series 2, 10B, 5JR+, 5JR, 5A, 4.5, 4, RTA 11T X2 pairs, RTA 8T, LSI9, LSI7, RTI A7, RTI A3, CSI A4, CSI A6, F/XI A4, RTI4. That's all for now.
    Great Customer Service!!! B)
Howdy, Stranger!
