Flush mount SDA SRS 2
CH46E
SDA SRS 2
The guy who traded me acoustic room treatments with install (Owens Corrning 703) had asked if it would be ok to flush mount them into a wall. They are going into his recording studio for wow factor.
I told him i would ask for him. There would be no toe in of course, i explained and showed him the manual for thier set up.
I did tell him that you dont want a bunch of stuff between them.
BTW: my system sounds so much better. Cant wait to really sit down and listen.
Best Answers
They may get rather boomy... Distance to wall is critical to balancing the bass output.
They need to come forward at least four inches from anything that may be set between them, and should not be enclosed.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
He said they would be surrounded by bass traps.
Won't make a difference, they are not a speaker designed to be in a hole.Political Correctness'.........defined
Answers
I passed along the info. Thanks guys!
Maybe a certain rabbit hole I keep hearing about?Don't take experimental gene therapies from known eugenicists.
