Third times a charm?
ALL212
Gots a new thing in pieces!
So far...
So far...
Aaron
Enabler Extraordinaire
Cool! Keep me in mind if selling eventually becomes an option. I passed on the first 2 offerings. Now I'm on a waiting list.
Anxious to see the build progress
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Nice
Looks like fun!
Which model did you go with?I disabled signatures. -
Silver stereo.
Blake - I’ll keep you looped in and you’re #1 on the list,
Another step done.
Aaron
Enabler Extraordinaire -
pieces.
are.
good.
mhardy6647 wrote: »pieces.
are.
good.
Not when its my gear. For me, pieces means that it may never be assembled correctly ever again. -
mlistens03 wrote: »mhardy6647 wrote: »pieces.
are.
good.
Not when its my gear. For me, pieces means that it may never be assembled correctly ever again.You are young, young Jedi. Experience, it will come.
Yoda Trioda -
Lol... Blake... Brock...
I’m a moron..Aaron
Tonight’s progress. Directions for this are terrible, doable, but terrible.
Aaron
I knew who you meant. Looking good!
Directions?! Ever see the Venn diagram describing men and directions?
There is no intersection.
Directions:
Step 1:
I don't mind that you have to figure out where the proper resistors go on the board - read schematic, place proper resistors. Insure you have a MM.
Step 2: build the chassis...what? when done with step 2 you've successfully built the chassis. There is nothing in it but you've built the chassis. If you've mounted the circuit boards you have a chassis with two circuit boards in it but no connections or connectors.
Step 3: place the connectors - maybe step 2 should go at the end?
Now realize that the pictures are not of the connectors you have. Wing it.
Step 4: wiring... "use some wire". ok...I can do that, but how much? Do I have enough?
I think the major whoops is step 2 - it needs to go later in the build.
Again - doable...but could be so much better!
I'm at step 1.5 - realize that step 2 is in the wrong spot and how do I figure out how much wire to use with it disassembled so at assembly I don't come up short or have an extra 10' of wire in here.
Bitchin' session over...
Aaron
mhardy6647 wrote: »mlistens03 wrote: »mhardy6647 wrote: »pieces.
are.
good.
Yoda Trioda
HA! Love the Star Wars reference.
I actually fully disassembled a receiver the other day (an Onkyo TX-V940) down to every single board, and actually put it back together! My skills are increasing!! -
mlistens03 wrote: »mhardy6647 wrote: »mlistens03 wrote: »mhardy6647 wrote: »pieces.
are.
good.
Yoda Trioda
But does it work??? -
are.
good.
Yoda Trioda
But does it work???
uh... I-uh... hmm... well... ye-no.
But in my defense, it was already broken when I started. The only reason I took it apart was to find something amiss... but, alas, there was nothing to be found. -
Nice work but you need a refresher course on symmetry. Phillips screw heads should all be clocked in the same position.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I had to throw the whole thing away... I couldn't get all the screw heads clocked right.
Finis… The directions just plain suck but it is doable.
Wire layout just prior to mounting the back panel:
Cat 5 wire to led, their "speaker connection" wire to power supply, Mogami from inputs and a stripped out Canare wire to the speaker outs.
Back panel completed:
The Back of the back - middle connector does nothing but fill a hole. Use that for balanced in on mono's.
The Front of the front - that switch - does nothing but fill a hole. Power switch is on the back where it should be.
It plays! Will need to put it on something other than the test rig to see what it can do.
Aaron
Kewl! Nice work! I really dig the bat handle switch! We'll have to think of an alternate plug for the front panel switch.
BTW, nice you see you got some class.....Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Nice!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
SCompRacer wrote: »Kewl! Nice work! I really dig the bat handle switch! We'll have to think of an alternate plug for the front panel switch.
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »How about a power meter with a soft blue glow...
The answer, right here!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
BTW, nice you see you got some class.....Quickly, Robin! The Bat Handle Switch!
SCompRacer wrote: »BTW, nice you see you got some class.....
I thought I got shots to keep me safe from that!Aaron
I gave it a real job. Volume on pre @ 3 o’clock
Aaron
Not when its my gear. For me, pieces means that it may never be assembled correctly ever again. You paid your money and took your chances ...Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Sweet jebus, IIRC 88dB sensitivity? What a workout!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
And now a bit of crow...kinda.
Found out the 1.6 build directions had yet to be done and are not yet released. So...you release a build without direction? No wonder I was a bit confused and aggravated.
That back switch is for flipping between balanced and not balanced. Since I am not balanced and don't intend to be balanced it stays.
The switch of the front is, indeed, the power switch on a normal build. I am also not normal so it stays as is, unused.
BAJEEZUS!!!
On the other hand - this thing is nice. The Carvers have its temp up a bit but nothing has caught fire yet. I've been listening for a couple of hours and no fatigue and no bitchin.Aaron
What is really ironic is that, other than wiring and upgraded caps, I intended to build this stock.
Oops .Aaron
