The Tale Of 5 Tweeters - SDA Tweeter Replacement Guide
Introduction
This article is aimed at those who want to be sure that they are choosing replacement and upgrade tweeters according to Polk's specifications and recommendations. Of course, owners are free to make whatever tweeter and driver replacements/substitutions they wish with their speakers. Some owners my subjectively believe that a non-standard tweeter replacement sounds better.
The five tweeters used in the SDA series are: the SL1000, the SL2000, the SL3000, the RD0194, and the RD0198.
The RD0194 silk dome tweeter is the appropriate replacement for the SL1000 and SL2000. The RD0194 is a drop in replacement for the SL2000, but not for the SL1000 since they are different sizes and have different footprints. Fitting an RD0194 into a cabinet made for the SL1000 will require some cabinet modification.
The RD0198 silk dome tweeter is the appropriate drop in replacement for the SL3000 tweeter used in the fifth generation SDA SRS series and in the RTA 15TL and RTA 11TL. The SL2500 is a cost reduced derivative of the SL3000 design. It was used in the Monitor 2 series speakers and in the RTA 8TL of the RTA series.
An alternative to the newer RD0 silk dome tweeter models is to track down the actual SL series tweeter, but those are not always available. Whatever replacement tweeter is chosen, it is highly recommend to invest in a Dayton Audio DATS V2 Audio Test System ($100) (or a similar speaker tester) in order to make sure that the tweeter is in proper working order.
Table 1 gives the typical electrical performance parameters of four of the five standard SDA tweeters. The nominal impedance of the SL2000 and RD0194 tweeters is 7.5 ohms. The nominal impedance of the SL2500, SL3000, and RD0198 tweeters is 5.6 ohms. The measurements in table 1 were made using the Dayton Audio DATS V2 Audio Test System.
Table 1. Measured Electrical Parameters Of SDA Tweeters
Glossary of terms for table 1:
Qts - A measurement of the total electrical and mechanical control of a driver. (no units)
Qms - A measurement of the control coming from the speaker's mechanical suspension system (the surround and spider). (no units)
Qes - A measurement of the the control coming from the speaker's electrical suspension system (the voice coil and magnet). (no units)
fs - A measurement of the free air resonance of a driver. This is the point at which driver impedance is maximum. It is the point at which the weight of the moving parts of the speaker becomes balanced with the force of the speaker suspension when in motion. (measured in Hertz)
Re - The DC resistance (DCR) of the driver. This measurement will almost always be less than the driver's nominal impedance. (measured in ohms)
Zmax - The driver's impedance at resonance. (measured in ohms)
Le - A measurement of the voice coil inductance. As frequencies get higher there will be a rise in impedance above Re. This is because the voice coil is acting as an inductor. Consequently, the impedance of a speaker is not a fixed resistance, but can be represented as a curve that changes as the input frequency changes. Maximum impedance (Zmax) occurs at fs. (measured in millihenries)
The measured values in table 1 provide some quantitative insight into why the RD0 series tweeters are upgrades to the SL series tweeters and why they are subjectively preferred by many SDA enthusiasts.
Test Tweeters
I had SL2000, SL3000, RD0194, and RD0198 tweeters on hand. I found a used SL2500 tweeter and two new old stock SL2500 tweeters on eBay. As of this writing, I have not located SL1000 tweeters that I felt comfortable with purchasing.
Figure 1. SL2500 tweeters.
Figure 2. Column 1-SL2500 tweeters, Column 2-SL3000 tweeters, Column 3-RD0198 tweeters.
Figure 3. SL2500 left, SL3000 right.
The SL2500 is similar in construction to the SL3000, and could be used as a replacement for the SL3000. However, as its overall lower Q measurements show, the SL2500 has lower performance with regard to driver control. This translates to lower performance in reproducing high frequency speed and detail.
Conversely, the RD0 series replacement tweeters have overall better driver control performance than their respective SL series counterparts.
The dome of the SL3000 has a shiny metallic appearance due to its vapor deposited metal layers. The SL3000 dome is composed of a triple layered (Tri-laminate, or "TL") construction with a top layer of stainless steel, second layer of aluminum, and third layer of clear polyamide. The SL2500 has a dull appearance and has a black polymer coating on the front and rear sides. It is not clear to me at this time if the SL2500's dome has a triple layer (Tri-laminate) structure similar to the SL3000's.
Figure 4. Rear side of SL2500 dome, left. Rear side of SL3000 dome, right.
Figure 5. SL2000 left, RD0194 right.
The 1989 versions of the SDA CRS+ and SDA 2B can be modified to support replacement of the SL2000 tweeter with either the SL3000 or RD0198 tweeters. The modification consists of the addition of a 5.8 uF capacitor in parallel with the 2.7 ohm resistor. This modification creates a contour network that corrects the rising high frequency response that would result from installing the SL3000 or RD0198 in these speakers. The SDA CRS+ and SDA 2B use the same crossover circuit.
Phase And Impedance Curves
The following phase and impedance curves for the SL2000, SL2500, SL3000, RD0194, and RD0198 tweeters are given in figures 6-10. In addition to the difference in DC resistance between the SL1000/SL2000/RD0194 and SL2500/SL3000/RD0198 tweeters, the differences in phase and impedance response highlight another reason why tweeter replacements must be chosen with care.
Figure 6. Phase and impedance curves for SL2000 tweeter.
Figure 7. Phase and impedance curves for RD0194 tweeter.
Figure 8. Phase and impedance curves for SL2500 tweeter.
Figure 9. Phase and impedance curves for SL3000 tweeter.
Figure 10. Phase and impedance curves for RD0198 tweeter.
PDF versions of these curves are attached below.
«1345
    F1nut Posts: 49,711
    edited August 2018
    Ray, nice work and I'm sure many will benefit from it.
  • westmassguy
    westmassguy Posts: 6,850
    Outstanding. I have a spare SL1000 I'd be happy to send you Ray.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • DarqueKnight
    DarqueKnight Posts: 6,760
    Jesse, I don't do lost causes. :)
    I wish everyone happiness with the tweeters of their choice. ;)
    pitdogg2 Posts: 24,481
    Outstanding Ray.
  • DarqueKnight
    PM Sent.
    mhardy6647 Posts: 32,929
    Splendid, thank you. This needs to be preserved for the ages (and I am not being facetious).
    xschop Posts: 4,636
    Very concise write-up. Can you tell if the 194's plastic frame is thinner or cast differently than the 2500/3000 frames?
    F1nut Posts: 49,711
    I don't think the plastic is thinner, but the casting is very different.
  • headrott
    headrott Posts: 5,484
    Excellent write up Ray. Thank you for taking the time.
  • DarqueKnight
    edited August 2018
    xschop wrote: »
    Thank you for your question. It allowed me to clear up a long-standing misconception I held about the RD0 tweeters' frame construction.
    With all the 2500/3000 frames' extensive cross bracing and deeper curvature, I expected them to be thicker, heavier, and more rigid than the RD0194 frames. The opposite was true.
    The RD0194 frame is actually 5.7 grams heavier than the SL3000 frame and 1.29 millimeters thicker at the center cutout. In fact, after taking thickness measurements, I placed the empty frames side by side and could easily see that the frame thickness at the RD0194's center cutout was substantially greater than that of the SL3000. Similarly, the RD0198 frame weighed 30.1 grams and was 3.36 mm thick at the center hole.
    The RD0 frames are also more rigid when trying to bend them using two hands.
    Upon receipt of my first RD0 tweeters, I vividly recall thinking that Polk had "cheaped out" on the frame construction. In this case my eyes deceived me, so my apologies to Polk for condemnation before investigation.
    This measurement exercise provided more insight into the RD0 tweeter's superior electrical and mechanical construction. I wish Polk had done a white paper on these tweeters similar to the one done for the SL3000.
    RD0194 frame on left, SL2500 center, SL3000 right. The SL2500/SL3000 frames are identical.
    RD0194 frame on left, SL3000 frame on right.
    The SL3000 frame weighed 23.8 grams.
    The RD0194 frame weighed 29.5 grams.
    SL3000 frame thickness around center hole was 2.07 mm.
    RD0194 frame thickness around center hole was 3.36 mm.
    The RD0198 frame weighed 30.1 grams.
    Due to the integrated structure of the frame and voice coil/dome assembly, I could not do a stand alone weighing of the SL2000's frame
    Post edited by DarqueKnight on
    xschop Posts: 4,636
    Again, thorough inspection.Thank you. I had a couple 194's that had severe plane run-out (flatness) where they bolted to the baffle. They contorted then resonated in certain frequencies when bolted down.
  • DarqueKnight
    xschop wrote: »
    Did you return them for replacement?
  • leftwinger57
    leftwinger57 Posts: 2,917
    Clearly music is subjective because it's an art form and all are entitled to their opinions. When it comes to proven science there should be no wiggle room w the exception of stubbornness. No golden ear here but when I changed out my old scratchy SL1000s to the drop in RDO -194 there was a better and extended listening time w/ the newer replacement tweeters. i can't be any more clear and direct than that......Lew
    I did notice that if tightened w/ the machine screws Toolfan provided it could warp the frame so I backed off and w/ the gasket made for an air tight seal...No TL mod here....
    xschop Posts: 4,636
    To Toolfan, the first set were donated and I kept for another rainy day project. The other set was new and sent back by person I helped with 10b's.
    Were going to try the Dayton DC28F when I get some more adapter plates done.
    To Dark knight, can you lift the SL2500 vs the SL3000 domes with a strong magnet? Depending on the amalgam of stainless, it may determine whether the 2500 has a metallic layer or not. JAT
  • DarqueKnight
    xschop wrote: »
    I wouldn't have expected either of the domes to have a magnetic metallic layer due to the tweeter magnet's strong magnetic field. I tried it anyway with the magnet of one of the tweeters and with another strong magnet that I use to clip notes to the side of my refrigerator. There was no magnetic attraction with either the 2500 or the 3000 dome.
    The SL3000's dome is translucent and allows points of light through. All of the three SL2500 domes totally block light. I used the "light test" to see if I could see any indication of a metallic layer behind the black polymer coating. One of my SL2500s was manufactured in 1991. The other two were manufactured in 1994.
    Light test: SL3000 dome on top of a flashlight.
    The SL3000 dome is translucent and allows points of light through.
    The layer structure of the SL3000's Tri-laminate dome structure is as follows:
    Top-Stainless steel, 0.00000394" thick.
    Middle-Aluminum, 0.00000394" thick.
    Bottom-Polyamide, 0.004".
    Source: SL3000 Dome Tweeter white paper, September 1989.
    Light test: SL2500 dome on top of a flashlight.
    The SL2500 dome is opaque and blocks all light.
    xschop Posts: 4,636
    At this point, the only way someone could definitively conclude the sl2500 having metallic layer is via GC/MS. Doubtful anyone here has one in the garage hehe.
  • mlistens03
    mlistens03 Posts: 2,767
    Great write-up, thanks! This will come in handy for many people (including myself).
    xschop Posts: 4,636
    Yes, please pardon my scientific methodology interjection.
    heiney9 Posts: 25,053
    edited August 2018
    Great scientific analysis from an engineer.
    H9.
    P.s. I have RD0194's in my 5B's and (2) pairs in my1C's. I have not noticed any sort of vibration, ringing or resonation in the 8 years I've owned them. Not very scientific, but it's my experience so that's really all that matters.
    P.s.s Thank you DK for yet another thorough write up and analysis. Definitely very informative.
  • sbb2112
    sbb2112 Posts: 134
    As an engineer, I tend to like to see data to support a conclusion. There are times that gathering data is difficult due to lack of knowledge of scientific methods of collecting or lack of proper equipment to do so. Sometimes an observation or opinion is just that without real supporting methods. I think there are 2 completely different things going on here. DK has posted factual data on all the tweeters listed and I have a better understanding of the differences because of it. My interpretation of the way the different sounds produced is my opinion and not a fact. In the end, I use the data to form a better opinion of the real world. I usually don't put out something with out either some data or a theory to support my opinions.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • pkquat
    pkquat Posts: 742
    GREAT information. TY :)
    Just throwing this out there. Any chance of a similar thread with data for the peerless, Denmark and USA, and maybe even the MT replacement. Non destructive of course. I am mainly curious about the specs.
    I'd be curious about the frequency response curves for all of the above, although I think some may be already out there. I know there is one for the SL2000, and I think one was provided for the RD0-198 that showed the attenuation as the frequency increased.
  • DarqueKnight
    pkquat wrote: »
    I wouldn't hold out a lot of hope for that. :)
    pkquat wrote: »
    Do a search Keith (Geppy1) had a thread on those back before the Vanilla switch.
  • gimpod
    gimpod Posts: 1,793
    Great job DK I've bookmarked it, lots of good info here should be a sticky.
    gimpod wrote: »
    Hey, howdy! How are you doing, sir?
  • pkquat
    pkquat Posts: 742
    pkquat wrote: »
    A little hope it is then :)
    gimpod wrote: »
    How many agree's are needed to make this happen.
    I found this one, which I knew about. Do your remember one with specs?
    pkquat wrote: »
    No Keith is not like Raife, he does not have the equipment for that.
    Tony M Posts: 11,009
    I'm for a sticky for sure!
    It's nice to know the replacement tweeters are BETTER than the originals in substance and performance. B)
    They sound softer at first but then they sound right after a couple of weeks. That's my experience with the RD-0194 replacements anyway. Sibilance is greatly reduced too.
    Thank you Raife for doing that study! ;)
  • DarqueKnight
    edited August 2018
    SDA Tweeter Measurements Table Revised To Include SL1000 Tweeter
    Thanks to David (@westmassguy) for the loan of the SL1000 Tweeter.
    I like the SL1000's elegant brushed aluminum frame.
    Table 2. Measured Electrical Parameters Of SDA Tweeters (Revised)
    Phase and impedance curves for the SL1000 tweeter.
    A PDF copy of the phase and impedance plot is attached below.
  • HzTweaker
    HzTweaker Posts: 723
    Fantastic thread! There's a lot of good information here. Thanks DK.
    2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
