Owens Corning acoustic panels on sale today at Home Depot
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • mhardy6647mhardy6647 Posts: 18,417
    wow, looks like quite a deal!
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • F1nutF1nut Posts: 39,993
    If one paints the outer material does that not inhibit the panels ability to absorb sound?
  • pitdogg2pitdogg2 Posts: 10,242
    edited August 4
    One would think YES
    I can't believe the colored versions are so much more expensive.
  • delkaldelkal Posts: 246
    I was thinking the same thing. You certainty wouldn't want a hard gloss enamel paint.
    But I don't even know how a flat surface can "suck up" the sound. Is it some kind of fabric coated foam? Can my 24x48 velvet picture of Elvis do the same?
    You can buy acoustic panels from Soundproof Cow or Acoustical Solutions at their regular price for slightly more than Home Depot's sale price and you have a lot more fabric and edge options.
    edited August 4
    delkal wrote: »
    The fabric covers a fiberglass core, which is what really absorbs the sound. Of course, the sound has to be able to pass thru the outer covering.
    The velvet will absorb some sound, but Elvis may not like what he's hearing.
  • SCompRacerSCompRacer Posts: 6,844
    edited August 4
    SonoKote sells an acoustically transparent paint. I have no experience with it, just read about it being available. Be interesting to see what the difference between acoustic paint and fabric would be. I'm thinking fabric would be better but don't honestly know.
    One can always buy acoustic fabrics in colors of choice, like Guilford of Maine, for their diy treatments. I purchased some GoM fabric when I recovered a four GIK thick panels to match the four GIK bass Tri Traps I had purchased. The wife chose the color so it was easier to have them. lol
    Some sellers have a minimum quantity of fabric you must purchase, others will sell by the yard but you may pay more per square yard.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • motorhead43026motorhead43026 Posts: 2,603
    Use paints specifically for textiles, should not be a problem.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk Signature S60's;Cables: Wireworld Eclipse IC; Audioquest Big Sur IC; Zu Audio Mission speaker cables; PS Audio AC-3 power cords, all into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; SDA2BTL's, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage.
    Political memes posted as fact and accepted as fact, are sign language of the ignorant, for the ignorant
    tonyb said " but even socialists can do a good thing here and there
    edited August 4
    I don't think the average person would consider that and it might be difficult to get textile paint that matches wall paint.
    The Home Depot video does not mention anything about the type of paint being used.
  • HermitismHermitism Posts: 1,826
    Food coloring. I win.
    2.0 - Marantz NA8005 | Polk LSiM703 | PS Audio: Duet, Power Port Classic, PerfectWave AC5 x2 PC | Wireworld Equinox 7 IC | Sanus UF30 | OC703 Panels
    6.1 - Pio Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | Monster HTS 5000 | DCF124BW x3 SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate x2 HDMI | M850SW | PS Audio Power Port Classic x2 | OC703 Panels
  • DaveHoDaveHo Posts: 1,872
    Fabric dye. Make some tie-dye t-shirts with the extra.
  • Tony MTony M Posts: 5,610
    edited August 4
    I thought the video said primer and then latex or acrylic paint. Yep, it does.
    That is what fabric paint is, acrylic.
    edited August 4
    Tony M wrote: »
    I stand corrected. Yeah, no way that's fabric paint.
    Post edited by F1nut on
  • BlueFoxBlueFox Posts: 10,054
    Apparently, you can order it paintable.
    “The cores of our SolSerene panels are constructed with a rigid acoustical core and are then covered with either an acoustically rated fabric or with a paintable surface. ”
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Yes, I know. The issue is after it's painted how well does it do at absorbing sound?
    edited August 4
    Tony M wrote: »
    I stand corrected. Yeah, not way that's fabric paint.
    Right the video has latex/acrylic paint, not fabric. I would think fabric paint would be less likely to inhibit sound absorption. That is the only reason I mentioned it. Sure your choices are limited , but most people want a contrast anyway.
    You just need to play music loud enough to break through the paint. :)
    To me, they are too plain looking. I have seen others with designs, patterns, etc on them that are more appealing.
    Lumin S1
    Sony XA-5400ES SACD
    edited August 4
    BlueFox wrote: »
    That would be me on certain occasions. :D :p
    I don't get the solid surface panel either. Maybe they think the sound entering from behind will be absorbed. But if the front is solid, it would act as a radiating panel, although the sound would be lower in volume due to some reduction from the panel catching some of the soundwaves.
    I agree, I don't get the solid surface idea either. Cloth, yea. 100% ;)
Howdy, Stranger!
