Interconnect cable for Polk SDA II
I am making new speaker cables for my Polk SDA II's and wondered what is the optimum length interconnect cable if the speaker cables are 9.5' long? I would think you would want the interconnect cable length as close to the speaker cable length as possible. I have never seen the factory cables for these speakers so I don't even know what length they were.
  • F1nutF1nut Posts: 40,392
    The original SDA cables were a minimum of 20 feet long, some longer. However, there is no optimum length, so make them as long you need them to be.
  • Scott99Scott99 Posts: 33
    I would think excessive changes to the length of the interconnects and speaker cables could affect timing of the SDA. If the original interconnect cable was a minimum of 20'. What was the length of the speaker cables that came with the SDA's? Assuming they came with the speakers.
  • ken brydsonken brydson Posts: 7,145
    Speakers never come with cables unless we're talking HTIB...
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
    It came that length in a cover all bases way. 20 feet is way more than most people would require.
    Ok, thanks. I will stick with my theory that the interconnects should be as close as possible to the length of the speaker cables just in case it makes a difference. Thanks again guys for the information!
    The length doesn’t make a difference. The quality of the cable used does.
  • pitdogg2pitdogg2 Posts: 10,850
    ^^^^^^^^THIS^^^^^^^^^^^
  • FestYboyFestYboy Posts: 2,783
    Remember, the signal is traveling the speed of light... 2.036494e−8 of a sec for those 20ft
    ^ for those not familiar with scientific notation, that number reads 0.00000002036494 sec.
  • Viking64Viking64 Posts: 3,290
    FestYboy wrote: »
    Well, that clears things up a whole bunch. :o :p
  • KennethSwaugerKennethSwauger Moderator Posts: 6,623
    edited August 3
    In most cables electrical signals travel at about 2/3 the speed of light. The electrons inside the metal move at a snail's pace called the drift velocity. They don't have to move very far until they bump into another electron, which in turn bumps against another electron. Kind of like a line of tumbling dominoes.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
    Ok, so that makes it: C=y+(.5y)
    3.054741e-8 seconds.
    Point being: you can't detect the difference, even at 10 times that length.
    Well there are several other things to consider. You would not make your left speaker wire 5' long and your right 20' long. The longer cable would have added resistance, more length to be exposed to different types of interference, difference in capacitance, etc. Especially when lower quality materials are used to make the cables the less of it you want in the signal path. Most of us take great care to make sure all our speaker drivers are getting the same quality signal. Why would we not want to make the same considerations with our SDA drivers?
    We have been talking about cables of equal side to side length.
    My original question was asking "What is the optimum length interconnect cable if the speaker cables are 9.5' long?" The way I understand it. If you have 9 foot speaker cables and a 20 foot interconnect cable. Your SDA drivers have the equivalent of 29 foot speaker cables and your other drivers have 9 foot speaker cables powering them. I would think we would want to try and make the interconnect cable as short as possible to try and get the same quality audio signal to all drivers.
    You're over thinking it. The difference between 9.5 and 20 feet is not going to affect the sound, the distances are too short. Therefore, the optimum length is whatever you need it to be.
    See my post on August 3rd.
Howdy, Stranger!
