WTB: Dreadnaught.
I need a dreadnaught. Used it new.
  • Mr_HzMr_Hz Posts: 148
    Two different specs... which are you looking for? The slighly lesser spec unit is easier to obtain... toroidal xformer can be purchased directly as a stock item, while the higher audio spec version requires a group buy.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • audioluvraudioluvr Posts: 447
    Agreed, build your own. I built the 750 for less than $200 ish. Running mono amps and loving it!
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    B&K Reference 50 Pre
    B&K M200 Sonata Monoblocks
    Cambridge Audio DVD 99
    Sangean HD FM Tuner
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
  • F1nutF1nut Posts: 40,391
    audioluvr wrote: »
    Agreed, build your own. I built the 800VA for less than $200 ish. Running mono amps and loving it!
    Fixed for ya.
    audioluvr wrote: »
    Fixed for ya.
    Oops. Thanks Jesse
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
Howdy, Stranger!
