Polk MC60?
I'm a long time Polk fanatic. Will Polks 6.5 inch MC 60 Ceiling speakers install in my car doors that have 6.5 inch speakers. As long as they're 6.5 inches they should fit unless they are too deep. Thanks for the help, from Noobie.
  • TopperDudeTopperDude Posts: 53
    The MC60 is not designed for automotive installation. Its an architectural speaker for homes. What you want is either the Polk DB652 or the higher-end MM652.
Howdy, Stranger!
