Interesting read.....
heiney9
Pretty cool. I like that their stuff is assembled in house.
Interesting, indeed. Thanks for sharing
I wouldn't trust Nelson Pass to sort my garbage.....
One of the best amps I've heard- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Oooooh how I have sellers remorse of my past Threshold/Pass amps
Brock TFS2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Oooooh how I have sellers remorse of my past Threshold/Pass amps
Brock TFS
I could add more fuel to the fire. This will be my next amp.
https://theaudiobeatnik.com/pass-labs-xa25-pure-class-power-amp-hpa-1-preamp/
Same writer as the tour article.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Would you trust me to sort your garbage?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Thanks for sharing. Top shelf company for sure with superior customer support.
The Pass Labs room at Axpona was a joy to check out. They had all the their amps broke down in sections. The guys were a complete joy to talk to and really got into the gear and knew other manufactures gear as well as their own. Made for some interesting conversation.
Thanks Brock -
Sure. Come on over.... It's mostly bottles and beard trimmings. Easy peasy..... -
You trim that thing?!
Jeepers, if you didn't, you'd look like Cousin Itt.
Well -- a kinda tall Cousin Itt, I suppose.
On the hunt for a set of speakers
Nelson Pass is a hack.Political Correctness'.........defined
President of Club Polk -
That's the truth. Plus he is a Californian.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Nelson Pass is a hack...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
When I grow up and get big I’m gonna....Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
I wouldn't trust Nelson Pass to plug in a drop cord.
This coming from a guy that can't screw in a friggin light bulb, and uses a butter knife to fix a toaster while its still toasting the bread.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Hey, back off on Russ...
Is a good guy, didn't soil the bushes but did kinda piss on my shoe.
Which he apologized for.... -
nooshinjohn wrote: »
I just change out the whole fixture to get my point across and a knife in the toaster is better than coffee to kick start your day. You should try it.Hey, back off on Russ...
Yeah...My bad David. I thought you were a tree. -
You got lucky, seen him try to hump a leg or two after midnight2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
.....and not necessarily human legs either.
Just ask Ryan, ya share a room with Russ and you better bolt 2 sheets of plywood around your bottom half before going to sleep. Even then, you might be woken up at 3 a.m. by the sound of a drill with a hole saw.
For those that need a visual ……..HT SYSTEM-
lsi 9's -
But he'd pay you well to do it for him...
