butcher block cutting boards for equipment
marvda1marvda1 Posts: 3,186
edited July 19 in 2 Channel Audio
Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800, Usher R1.5
Transport/Dac: Cayin Venus cd-100i, Musical Paradise mp-d2 mkI
Speakers: Rosso Fiorentino Volterra
Speaker Cables: Analysis Plus Black Mesh Oval 9, Cerious Technologies Graphene Extreme
Interconnects: Analysis Plus Copper Oval-In Micro, MG Audio Design Planus Cu2,
Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
Post edited by marvda1 on
  • ConradiclesConradicles Posts: 5,748
    SDA end caps haha.
  • mark090852mark090852 Posts: 772
    edited July 21
    This guy's shop is just a few miles from me. He builds some beautiful isolation platforms.
    http://www.timbernation.com/
    Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers.
    Oppo UDP-203 Blu-Ray player.
  • DSkipDSkip Posts: 14,889
    They're beautiful pieces of furniture. Nothing more. There is no thought in these products about how they can actually influence the sound.
    He uses the term isolation platform, but there is nothing isolating about them. They are just slabs of wood with feet on them.
    I have always admired the beauty of his products though.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • EndersShadowEndersShadow Posts: 15,940
    edited July 21
    I've debated this but mainly because I could then drill through it and attach my towers to them and then put spikes on them and be good. My towers upstairs are 35lbs a pop and very skinny so they tip easy, even if I put them on spikes. I need a wide base to keep em from tipping.
    That said, I'd contact our local resident woodworker Ryan @ZLTFUL to commission some from him. He's got access to all the good stuff and knows what he's doing.
    I had to put plinths under the T50 like that Dan. It's a good solution given their weight and flimsy nature on carpet.
    If you get a heavy enough piece of wood then you don't need the spikes. Just more work and expense.
    audiothesis.com/
    Cabling: Wireworld
  • joecoulsonjoecoulson Posts: 635
    I run a cabinet company and our sister company does granite. I’ve always thought about making some platforms for my gear out of it, just never really followed through.
  • kharp1kharp1 Posts: 2,530
    DSkip wrote: »
    Really? No isolation?
    How come it's much harder to hear someone talking being a closed wooden door?
    Take a pair of headphones and put one side on one ear, and, on the other side put a piece of the 2, or , 3 inch butcher block over that ear before putting the earphone on. Tell me it doesn't isolate.
    Perhaps it doesn't isolate as well, or, at the optimal frequencies as other materials, but, there is some isolation.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
    Proper isolation takes more than just a slab of wood. At best, these slabs can be considered tuning devices because they will impart their own sound onto the component. I've used them with success in the past but I don't want anyone looking at them and considering them isolating platforms.
    Of all the ones shown, the one zeppage listed would probably be closest to what isolation is but still a far ways away. The composite build of the plinth will help reduce the resonance but not eliminate it.
    As far as granite, it's beautiful but has no place in an audio rig. Granite and stone slabs are hard and thus introduce a hard resonance to your system. It will cause it to sound colder and shrill. I wish it wasn't so because nothing is prettier than a nice piece of granite.
    audiothesis.com/
    Cabling: Wireworld
  • hochpt21hochpt21 Posts: 5,043
    __________________________________________________
    Turntable - VPI Scout 1.1/Ortofon 2M Blue
    Integrated Amplifier - Rogue Audio Cronus Magnum II
    Speakers - GoldenEar Triton 2
    7.1 Home Theater
    Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ W1070; Elite Screens 120"
    Man Cave
    Turntable - 1) Pro-Ject 2.9 Wood/Grado Gold; 2) Sony PS LX410/Grado Green
    Phono Stage - PS Audio GCPH, Parks Audio Budgie; CD - Marantz DV4001
    Preamp - Dared SL2000a, Luminous Audio Axiom II; Amplifier - Parasound HCA-1500A
    Speakers - SDA 2A (x-overs etc...); Epos Epic 2; Polk Audio Monitor 70 (my first)
    Nice plinth! B)
    I have no issues with the products, just the description. I think it sets misleading expectations that even Kerry was hitting on.
    audiothesis.com/
    Cabling: Wireworld
    DSkip wrote: »
    Nice plinth! B)
    I was getting a lot of skips with footfalls in a previous setup and the weight of the butcher block helped tremendously.
    In this setup, with the Ginkgo cloud... the butcher block is mostly to look cool. ;) B)
    7.1 Home Theater
    Man Cave
  • txcoastal1txcoastal1 Posts: 9,902
    I'd rather use glass and granite :#
    txcoastal1 wrote: »
    I'm laying marble over my oak floors, and, lining my walls with glass from floor to ceiling to help bring some high frequencies back that the tubes are lacking. Want to get a bit more of an "etched" sound.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    kharp1 wrote: »
    txcoastal1 wrote: »
    That'll have a nice ring to it :)
    Don't forget to use Waterford bowls for your speaker enclosures. Beautiful and functional. Just be careful drilling out the terminal holes.
    audiothesis.com/
    Cabling: Wireworld
  • pitdogg2pitdogg2 Posts: 10,854
    Rocks and glass always a nice combination
  • marvda1marvda1 Posts: 3,186
    none of you know what you are talking about. although a little pricey, bulletproof glass sounds the best. :D
  • Viking64Viking64 Posts: 3,292
    Wind chimes hanging right up against your subwoofer = bliss
    Wind chimes would turn to glitter in front of my sub
  • Moose68BashMoose68Bash Posts: 3,541
    @marvda1,
    I've used Boos Block cutting boards on a couple of speaker stands.
    https://www.johnboos.com/product_group.asp?s=c&grp=JBC0051
    Have a look.
    Family Room, PS Audio PW Transport, DirectStream DAC; AQ Sky XLRs, Perreaux SM6 MKII Pre; AQ Sky XLRs, Perreaux Prisma 750 Amps or CAT 600.2 Dualmono Amp, Morrow SP7 Speaker Cables, SDA SRS 1.2tls (RD0198s, Dreadnought, Black Hole 5, Acousta-Stuf, Dynamat Extreme, JBWeld. Vr3 Mods: "The Abbot" Monastery-Level Xovers, Custom Internal Wiring, Binding Post Plates, & SDA ICs).
    Exercise Room, Wadia 171 iPod Dock, PS Audio PerfectWave MkII DAC, AQ Sky XLRs, Perreaux SM6 Preamp, AQ King Cobra RCAs, Perreaux PMF3150 Amp, Dreadnought, Supra Rondo 4x2.5 Speaker Cables, SDA 1Cs (Vr3 Mods Xovers).
    Synology 713+ NAS on Gigabit LAN serving PW MkII DAC & DirectStream DAC.
  • verbverb Posts: 3,354
    DSkip wrote: »
    Agree with Skip. They are massive, heavy, and stiff. Good for minimizing deflection for heavy components, but additional isolation (spikes) would be required. And they are quite nice looking. Many wood species/combinations available.
    Easy to modify to the right size if you have a table saw. More cost effective if you buy larger boards.
    Basement: Polk SDA SRS, Micro Seiki MB14 TT, VTL 2.5 Pre, Marantz CD6006 CDP, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    Spare Room: Dayens Ampino Integrated, Auris BluMe, Polk TSi200's
    Living Room: Pioneer SX-N30 Network Receiver, Pioneer PD10AE CD Player, Furman M8-LX Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi Subwoofer
  • msgmsg Posts: 4,270
    kharp1 wrote: »
    txcoastal1 wrote: »
    Save your money. I've got some RTi10s I'll send you.
  • machonemachone Posts: 1,008
    All kidding aside and certainly not wood is acrylic sheet. Acoustically it is dead as a door nail.
    I use 1 inch thick set on Sorbothane hemispheres for certain components.
    It cuts great on a table saw and with the edges sanded it looks attractive.
    Mojo Audio Joule v5>>Quantum Byte w/JRiver 24 and Fidelizer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts PA-6 Elite Mod)>>
    SRS 2.3TL (Fully Modified)...SDA-1A (Fully Modified with Dimensional Tweeter Delete)
    1KVA Dreadnought
    Marantz SA 8005
  • SCompRacerSCompRacer Posts: 6,914
    edited July 25
    hochpt21 wrote: »
    The Gingko Cloud is the best TT isolation I have ever used.
    You've really stepped up on the TT path. Very nice! Isn't it amazing, the difference you hear with a significant TT upgrade?
    Slate plinths are great for turntables.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
    SCompRacer wrote: »
    hochpt21 wrote: »
    Thanks Rich! I’ve slowly been upgrading pieces but haven’t found the time to post on here about them! Having 3 kids will do that to a guy.
    I still have the Pro-Ject you helped me get from Rob. Believe it or not, but I’ve enjoyed it for 5 years already!
    Still have some configuring to do and then I’ll start reviewing gear.
    You are correct. I didn’t actually expect much, but the Scout surprised me with how much better it sounds. It’s amazing.
    7.1 Home Theater
    Man Cave
    Big step from the project to the scout (assuming same cart)?
    Different cart so that definitely plays into it. Grado gold to Ortofon 2m Blue. But I also had a Sumiko Blue Point 2 on the Pro-ject at one point, and the whole setup I have now is superior as far as my listening tastes are concerned.
    7.1 Home Theater
    Man Cave
    hochpt21 wrote: »
    Our daughter and niece (whom we were legal guardians for), are all grown up and on their own. Just the wife, me a cat and dog.
    Rob lusted for my Nottingham Space 294. When it was time to sell, I took it there and put his cartridge on it. It sounded much better in his system. Then we upped the cartridge. No way I was leaving with it....
Howdy, Stranger!
