Saw some sweet Allison ‘s for sale. Looked like Bose 901’s?
DabutcherDabutcher Posts: 1,565
edited July 10 in Vintage Speakers
Antique store was asking 600 with chrome Bose stands. Peace. Dehid7j0g9psj.jpeg
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • mhardy6647mhardy6647 Posts: 17,999
    Nothing like Bose 901s :) although, in fairness to both Dr. Bose and Mr. Allison, both loudspeakers were designed to work their best in real-world environments (i.e., in real rooms in real dwellings).
    The Allison Four was the - heh - fourth model down the line of the original Allisons, and was/is a pretty darned good 'bookshelf' loudspeaker.
    I like the Allisons a lot. Roy Allison was, of course, an AR alum, and lived a good long life (he died last year, or maybe 2016, too lazy to double check, sorry) and had several companies of his own when it was all said and done. Allison Acoustics (from which the Four derives) was his first post-AR venture (AFAIK).
    More Allison info at www.classicspeakerpages.net (and/or its forums).
    http://www.classicspeakerpages.net/library/allison/
    I'd opine that if one likes the early "Monitor Series" Polks, one'll love the Allisons. I certainly do. :)
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
    There was a time (late 1960s/early 1970s) that it seemed like everybody -- well, at least everybody in New England :) -- was building a loudspeaker that was at least evocative of the 901. At least in some respects (e.g., sometimes bass-ackwards relative to the 901 ethos, and rarely if ever with FR drivers, other than the 901 itself). :|
    To wit:
    KLH [28]
    (image from www.classicspeakerpages.net)
    AR [LST]
    (image from https://cmtechsupport.com/ar-lst/)
    EPI (Epicure) [M601/M602]
    (images from www.humanspeakers.com and http://www.audiocircuit.com/Home-Audio/EPI/602 [respectively])
    It's like all of these guys worked for one another at one time or another ;)
  • westmassguywestmassguy Posts: 6,044
    I'll still take my Series II Continentals
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    those are elegant :)
  • Dennis GardnerDennis Gardner Posts: 4,731
    edited July 10
    The Allison Fours were some of my favorite bookshelf speakers in the early '80s. The only thing to watch for is the plastic grills will be so brittle by now that even removing them carefully may destroy them and they are not available anywhere. The same issue ran throughout the whole line. The Allison Model 1s were great too, but required a setup much like the SDA line with hard surfaces nearby causing lots of reflections with the triangle shape.
    re: the grilles. Yup.
    There are reports of "reinforcing" the oh-so-brittle grilles (which, I think, are made of ABS plastic), if one is fortunate enough to be able to remove one's grilles intact.
    Here's one:
    http://audiokarma.org/forums/index.php?threads/method-for-preserving-allison-plastic-grilles.262849/
  • dromundsdromunds Posts: 6,992
    AR [LST]
    I had a pair of those AR/LST’s. Truly great speakers. Had them paired with S.A.E. Mark amp and preamp. One of my big regrets is that I traded them in during about 1981. Now unobtanium.
    Yes, they (the AR-LSTs) were something, indeed. Notoriously hard to drive/picky of amplification, if memory serves.
    Interestingly, Mark Levinson resurrected them after a fashion -- and, I believe, rather briefly (?) -- under the aegis of his post ML company, Cello.
    http://www.celloseattle.com/ctdocs/prodserve/speakers/proamati.html
    As an aside, and @dromunds probably knows this, there were two bargain versions :p of the AR-LST: to wit, the AR-LST2 and the AR-MST. The latter, with all cone drivers, is of interest to me because -- well -- as it happens, I have a torn-down pair of them sittin' in the basement. Another project for someday :)
    OK, I am being all OCD now.
    for posterity:
    AR-LST
    AR-LST2
    AR-MST
    Now, in fairness, these loudspeakers are more "anti Bose 901" than are they "Bose 901 related" :) They are more about "dispersing direct sound", methinks, than "direct/reflected sound. But, still, they look kinda 901-sy.
    sources:
    http://www.vintage-speaker-review.com/2012/07/acoustic-research-lst-and-lst-2-ar-lst.html
    http://www.classicspeakerpages.net/IP.Board/index.php?/topic/8963-ar-mst/
    Yes, I’ve heard the AR-LST2’s and in the immortal words of Lloyd Bentsen, “Sir, you are no LST”. Never heard the MST. Interesting info about Levinson’s speakers didn’t know about them. Below is the invoice from 1983 when I traded in my LST’s. I suppose it’s time to move on now. Lol. They were truly remarkable in the proper set-up.
    I am sure I've mentioned this before :p but my ugly-but-fully-functional pair of dump-find AR-3s gave up their drivers to a Cello Amati restoration project :) I am quite proud of that, as you can tell.
    I've never seen nor heard the LST2, but I don't doubt your assessment. I am curious about the MST, mostly because those AR cone tweeters were really not bad. Safe to assume the MST's not in anything like the same league as the LST, tho'. :|
    My presumption would be the MST's would very significantly best the LST2's. I really like some of those vintage speakers. The original Large Advent is another of my faves. There was a real passion, they lived their designs.
    I liked Mr. Polk's Monitor Series Model 7 rather better than the OLA, which is probably why I (still) squander so much time here rather than, say, www.classicspeakerpages.net ;)
    That said, I heard a pair of OLAs that had been refreshed by simply replacing its XO capacitors. No more, no less. The new capacitors, if memory serves, weren't particularly boutique (I think they may have been the "Dayton brand - Bennic - polypropylene caps sold by PE) -- but they resulted in a phenomenal improvement in the smoothness & transparency of the OLA sound compared to what I remember.
    There's a pair of Utility Advents in the basement that I really need to refoam & "recap" some day. Imagine that. :|
    I would say the Monitor 7's also fit into my "real passion, they lived their designs" category. I very much enjoy them also.
    I plan to bequeath the pair of 7As here to the next generation of Hardys when I hit the dusty trail ;)
  • pitdogg2pitdogg2 Posts: 10,032
    Don't you live on a dusty trail??
    edited July 12
    touché
    OK... howzabout when I have shuffled off this mortal coil?*
    :p
    _________________
    * https://www.phrases.org.uk/meanings/319800.html
  • Jimbo18Jimbo18 Posts: 1,739
    touché
    :p
    _________________
    You have coils? Lots of people are going to memory foam.
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, RT25i surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Even more modest Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
    Jimbo18 wrote: »
    touché
    :p
    _________________
    Too bad Vanilla doesn't let us give fractional likes.
    -- by the way, I have the distinct feeling that I've managed to chase the OP (@Dabutcher) away from his own thread entirely!
Howdy, Stranger!
