Sealing Cabinets
Please forgive what is most likely a really basic question. I'm modding my CRS speakers. The seams on the inside of the cabinet appear well-sealed with a thick layer of glue - except for a very few spots. I'm reluctant to disturb the present sealer, but want to, at least, hit the few spots where the glue doesn't cover both sides of the seam.
Can I put Loctite Power Grab over the existing glue in those spots? Or, might the Loctite affect the integrity of the glue?
Thanks for helping a guy seeing the inside of a speaker cabinet for the first time!
  • mlistens03mlistens03 Posts: 1,810
    If it was me, I would just apply more glue in the spots which are leaky. Or, I would remove the old glue, fully disassemble the cabinet, and then reassemble it, and be generous with the wood glue. Probably neither of these approaches are the best, but both are about where my talent with wood runs out. :wink: :lol:
    Not Tom, or Trey, or Jim
    Main setup:
    Speakers are one of three, Mission Freedom 770 IV’s, Polk LSi25’s, or Polk SDA-CRS (stock XO, SL2000’s, Blade/Blade model). Electronics are as follows: for the LSi’s and SDA’s, a Technics SU-v75 acting as a phono preamp, into a Yamaha RX-v665, into a Crown XLi800 power amplifier. For the Missions, I have a Lafayette LR-1100. Turntable is a Technics SL-3200, with a Shure M97xE. Cables are generic/soon to be replaced garbage.
    An old post I found on AK, from 2013.
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • ZLTFULZLTFUL Posts: 4,573
    Use a bead of Loctite Powergrab around the entirety of the internal seams and call it good.
  • Dr_WuDr_Wu Posts: 56
    I have no problem with that. Just didn't know if I could put it over the old glue or needed to chisel it out.
  • gudnoyezgudnoyez Posts: 6,286
    edited July 9
    I would also use Locktite Powergrab along the seams over the old beads after making sure to remove any loose pieces of the existing sealant.
    Are you with me Doctor? (sorry had to do that)
    Nice B)
  • I'm sure at this point you've already sealed up your CRS's. But I've found using a hair dryer and a putty knife works wonders for removing the old glue. I was able to get all the seams and giant pools of old glue out of my 2B's with little effort.
    The Night is Dark and Full of Terrors
  • pitdogg2pitdogg2 Posts: 10,564
    Sharp chisel works very well. Do not even need to heat the glue.
Howdy, Stranger!
