Recommends Me a Blu Ray Playa
kevhed72kevhed72 Posts: 3,319
Something new and not too high end, since this will be for our 2nd TV. Alot of the Samsung and LG ones look way cheap...perhaps a Sony or Yamaha?
Really looking to spend under 200 and dont need 3d or 4k....thanks
  • gudnoyezgudnoyez Posts: 6,350
    Sony UBP 800, but if you don't need 4k or 3D then just about any one you kind find at Walmart or best buy should do the trick, I would probably just get one of the cheaper Sonys and be done with it.
  • kevhed72kevhed72 Posts: 3,319
    Ill open up ideas to used Pioneer and other decent players....
    edited July 8
    https://www.sony.com/electronics/blu-ray-disc-players/ubp-x800
    Up your budget 50 bucks and get one of these you don't have to use the 4K and 3D options but will be available should you change your mind. I have seen these on E-Bay for $150, pretty versatile player for not much coin. I have been using mine more than my Oppo player latley.
  • motorhead43026motorhead43026 Posts: 2,799
    I am on the Oppo list for a 203. If I fail to get one this Sony mentioned above will be my default.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk Signature S60's;Cables: Wireworld Eclipse IC; Audioquest Big Sur IC; LAT International speaker cables; PS Audio AC-3 power cords, all into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; SDA2BTL's, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage.
    Political memes posted as fact and accepted as fact, are sign language of the ignorant, for the ignorant
    tonyb said " but even socialists can do a good thing here and there
    I just realized our TCL P series TV is 4k capable. I have not seen any 4k content yet so that Sony may be the ticket.
  • pitdogg2pitdogg2 Posts: 11,184
    kevhed72 wrote: »
    Do it...
  • mrlorenmrloren Posts: 1,528
    Get a Sony,
    I've owned or still have Samsung, Panasonic, LG and some off brand stuff. In the end it's always a fallback to Sony.
    Oppo and Pioneer Elite are better but out of your price range.
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • Airplay355Airplay355 Posts: 4,258
    TheUBP X700 is right at your budget. It's the same as the 800 except with a cheaper case, power brick, and smaller. It can do Dolby Vision where the x800 can't. The X800 looks like it's built better and is standard component size but it's a little more expensive. I went with the X700 and I have no complaints. It loads discs quickly and doesn't skip. My only complaint is it's a little noisy but I have it in a cabinet now and since it doesn't generate any heat (power brick outside cabinet), it can make all the noise it wants in there.
    https://www.amazon.com/Sony-UBP-X700-Ultra-Blu-ray-Player/dp/B078HXF9H2/ref=sr_1_5?s=electronics&ie=UTF8&qid=1531082093&sr=1-5&keywords=sony+ubp-x800
  • WhereYouWhereYou Posts: 9
    Check online and search the price under 200, you will found a lot.
  • Mr_HzMr_Hz Posts: 150
    I already have a modded Oppo UDP-105D + high end Pioneer Plasma, and have been slow (ok, non-action) to adopt 4k. But when I do... that Sony UBP-X800 looks like a reasonably priced option for 4K.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
Howdy, Stranger!
