How do I best clean the midbass? It has lint on it. How do I best clean/restore the rubber
RTA 11T
jr5
SDA SRS2
Answers
  • motorhead43026
    motorhead43026 Posts: 3,892
    Windex with ammonia.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
    F1nut Posts: 49,806
    Original Windex sprayed onto a soft, lint free cloth. Never spray the drivers directly. Use a circular wiping motion with light pressure. Be sure to clean the rubber surrounds at the same time. You'll find a lot of brown stains on your cloth at first from cleaning the surrounds. Clean the PR's too.
  • tonyp063
    tonyp063 Posts: 1,048
    Also be aware that the mid-woofers, even when clean, have a certain amount of tackiness on the cone.
    This is normal. Don't go overboard & try to clean it off.
