Audioquest Type 2 speaker cable review
Clipdat
This might be the quickest I've ever reviewed something after it's arrived, but my experience was so vivid that I don't feel a need to wait.
I ordered a 4' pins/spades terminated pair of AQ Type 2 SC from Audio Advisor for $50: http://www.audioadvisor.com/prodinfo.asp?number=AQT2NF
It fit my termination requirement of pins for the amp's spring clips, was inexpensive, but was still a step up in from the standard 14ga OFC Monoprice wire I was using for my Polk Audio Blackstone TL3 computer speakers.
As usual AA processed and shipped my order promptly. These cables are terminated in house and they were the cheapest custom terminated cables that didn't use regular stranded OFC copper wire that I could find.
Instead, they use 4 individually insulated solid long grain copper wires, twisted in a star pattern. Two each for positive and negative. Workmanship on the terminations seem clean to me, with a little bit of excess solder visible on the spades. I'd wager that more is better than less though in this situation.
Bonus pic. Hate spring clips and how either bare wire or pins are the only option with them. This just makes me nervous:
Moving on to how they sound! I had been using the standard 14ga wire since I got the TL3s so I had a good idea of what they offered. I always thought it sounded "just fine" and was doing justice to the TL3s. Well, I was wrong.
I hooked up the Type 2 cables and from the very first song I played, I noticed a difference in the way things were sounding. The most noticeable change was an effortless, smooth, and elegant quality that the sound had. The speakers were putting out a more cohesive soundstage, and stereo imaging was noticeably improved. I love the sensation of a nice thick stereo image, when it feels like the sound is whipping past and over your ears.
Information within songs was being presented differently. I can best describe it as a smoothness and grace that wasn't there before. In some songs, certain elements/instruments popped in and actually startled me because I hadn't heard them featured like that before. The clarity was literally surprising to me.
I can't adequately describe the feeling I now get when listening. It just sounds better. It's more enjoyable. I realize that technically that is a completely vague and subjective statement, but it's the honest truth.
These Audioquest Type 2 cables would be an excellent choice for someone looking to upgrade from standard 12-16ga stranded copper wire. As long as you have a decent set of ears, I don't see how you could NOT hear a difference. It's of course up to you to decide if that difference is "better" to you.
Overall I think that the Type 2 represents a great value, and with the nice termination options offered as well as the relatively inexpensive price, you'd be wise to give these a try if you're still using bare wire.
Good job. You are going down a slippery path. Enjoy.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Haha, I'm already down it. I already have Audioquest Bedrock SCs on my serious rig, soon to be MIT Terminator 2s.Good job. You are going down a slippery path. Enjoy.
Nice review, Drew. I got into some reading a while back on AudioQuest cables, designs and cable theory. They have a good bit of technical documentation on their site. Interesting.
Though I've never done it, I heard you could snip those pins if you prefer them shorter. I thought the indents were more to provide backup against slipping. I'd wonder whether snipping them could be detrimental somehow, with respect to exposing the core material and compromising the plating.
Another idea would be to get some skinny heatshrink to slide up and heat down to cover the exposed pin section past the indent(s) you'll use. I'd personally leave at least two indents to use.
Support the cables if you can. I use velcro ties to secure heavy cables to a rack, cabinet or stand to provide a bit a of strain relief at the connections.I disabled signatures. -
Just goes to show ya don't have to spend big bucks on cables to get better sound.HT SYSTEM-
lsi 9's -
Your review reminds me of how I feel sometimes when something new is introduced into the system....hearing something in a "different way". Many times I play the track again just to be sure I actually heard what I heard in the way that I heard it.....if that makes any sense at all!Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Thanks for the ideas, Scott. I had heard that as well that you can break/cut pins to shorten them. For now I'll let it ride as is and see how it goes. Should be fine as long as my cat doesn't go back there, which he usually never does! Somehow I got lucky and found the one cat in the world that doesn't shred the toilet paper roll or bite on cables.
The cables themselves are actually pretty light and flexible, so I routed them in such a way where they are somewhat being cradled by adjacent cables. There's little to no pressure or strain being placed on the spring clip terminals. And, like you suggested, I tried to let the spring clips "bite" onto the small indents/valleys to hopefully secure them further.Support the cables if you can. I use velcro ties to secure heavy cables to a rack, cabinet or stand to provide a bit a of strain relief at the connections.
I know the spring clips grab the indent on the pins but, that photo makes me cringe!
Nice review.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
These cables look very nice! I think these will be the top option when I get my gear sold. Good review as well!
Micah -
I am running type 8, have tried/have others but keep coming back to these.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
Anyone have comparison between these and the Furez wire that Doug sells? I have the 10g (due to longer runs) and enjoy it quite a bit. Specifically the FZ102AS wire.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I use AQ type 4 in my rig. best cables I've heard... would take a lot for me to consider switching....
The Type 4 speaker cable is an outstanding cable.
Dan
One of these days when I'm bored, I'll listen to 3 different AQ cables.
AQ type 4
AQ Aspen
AQ Wel
contrast as compare.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Great post....as I have been looking to change out my 14awg Monster cable in my family room rig.
How flexible is the cable overall? How close to a 90 degree bend you think you could get without jacking up the solid wires? -
I heard you're supposed to work any sharp bendy areas back and forth quickly at least 100 times to break it in and make it easier to work with. You'll know you're there when the cable bends easily on its own.I disabled signatures.
Interesting thread!
I was also looking at the Audioadvisor site and see they have Audioquest type 4's for about twice price of the 2's. You can get a 10 ft pair with their "no frills" terminations for $119. Not a bad deal since just buying the bare wire is the same price.
audioadvisor.com/prodinfo.asp?number=AQT4NF&opt=475|492|494|501
You can also get the type 4's factory terminated by Audioquest with the fancy braided sheath and (presumably) better connectors. They look great but the price goes up fast......a 10 ft pair is $280.
audioadvisor.com/prodinfo.asp?number=AQT4&opt=1160|1167|1169|1172
I assume the wire part will sound the same ugly/plain or fancy/sheathed. But are the better connectors worth $160?
The AQ "finished" cable look super nice but IMO way too pricey unless money is no object. Im basically wining becasue all the Type 4s on flea bay are somewhat outrageous price wise for used speaker cables.
has anyone tried audioquest gbc sspeaker acbles from hcm audio?
https://hcmaudio.com/products/audioquest-gbc-speaker-cable-full-range-pairAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
Pricey ? What's your idea of pricey ? Because you can buy some AQ type 4's straight from BestBuy for a tad over 100 bucks.
https://www.bestbuy.com/site/audioquest-8-type-4-speaker-cable-blue-black/9892721.p?skuId=9892721HT SYSTEM-
lsi 9's -
Im cheap and dont want to spend that much for my 2nd system....thats all. I had a pair of type 4s I scored for like 100 bucks used awhile ago and like a fool sold them.
By any measure, I don't think 100-150 bucks is pricey...for any system. Just sayin'.
Your system, be it the 1st/2nd/or 3rd, is only going to be as good as the weakest link. Don't make cables that weak link is all I'm sayin' and a tad over 100 bucks is totally reasonable.
Cheap is relative...my outdoor speakers have cheap cables. Still, they are AQ cables.
https://www.crutchfield.com/p_703X250W/AudioQuest-X2-Speaker-Cable-50-feet-White.html?tp=588&awkw=75643972945&awat=pla&awnw=g&awcr=47692541425&awdv=c&awug=9021493&gclid=EAIaIQobChMIuc3cstL82wIVisDACh0dFw7KEAQYASABEgLuL_D_BwE
100 bucks for a 50 ft. roll and they sound way better than the crap I had in there which were comparable to monoprice cabling. For 50 ft of cable though, too much higher up the ladder will cost ya a fortune.
For 8-10 ft though, spend the coin. Not like anyone has to eat spam for a month.
lsi 9's -
HCM Audio is legit. I've bought many Audioquest items from them. -
14g Monstercable is stranded but you still shouldn't bend it at 90 degrees. Soft bend work much better.
Dan
AQ type 4
AQ Aspen
AQ Wel
The magic with audioquest is that they build all their cables from the entry level models to the Wel's. You get a beautiful sounding system no matter what you spend on the cables. The gains you get are small as you go up the ladder and on many more entry systems you can't even hear any differences anyway because the system can't revel that level of clarity. It's like putting Perelli High end High speed tires on a car that can't reach the speed rating or handling abilities. Matching the correct tire to the car is key for not wasting money or products with no benefits to given situation.
So testing type 4 vs Well the system would have to be very high end to hear the differences. I would never buy We level cables for my system as it doesn't have that kind of detail and clarity.
I find figuring out what level is appropriate makes the most value for a given system. Just because a cable is technically better then another in a given system you might not be able to hear those differences.
I really learned this not just from my own trials and errors but from learning from the Engineers who design the gear and cables we love.
Have fun and do it sooner then later unless you don't want to give up a TON of your free time being a NUT like me. I probably should be locked away in a mental ward for the amount of time I spent testing cables LOL.
Dan
Best Buy confused me too. I was ready to get out my credit card till I realized that was for one cable. The "plain" Audioadvisor cable is for a pair (which is useful if you have a stereo).
I assume they sound the same.
Hi...I went for some monster speaker wire 50 ft. they had on sale for 19.99. A great price imo from a known brand. They were running around like their balls were being cut off, so I would put that down and get audioquest. 100 bucks for the audioquest 30 feet and 20 for the monster 50 ft. So I said I will be back. lol. I will go pickup the monster Friday. Thanks guys. I don't see who cable could make that big a difference. Why buy expensive speakers if a brand of speaker wire would make such a huge difference.
Excellent insight- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
JewelHanda wrote: »Hi...I went for some monster speaker wire 50 ft. they had on sale for 19.99. A great price imo from a known brand. They were running around like their balls were being cut off, so I would put that down and get audioquest. 100 bucks for the audioquest 30 feet and 20 for the monster 50 ft. So I said I will be back. lol. I will go pickup the monster Friday. Thanks guys. I don't see who cable could make that big a difference. Why buy expensive speakers if a brand of speaker wire would make such a huge difference.
Dan
Dan, your knowledge about cables is laughable, so I laughed.Political Correctness'.........defined
President of Club Polk -
Those that don't know, don't know that they don't know.Political Correctness'.........defined
