LSiM 707s: 2.5-3 dB difference
alucidideaalucididea Posts: 103
edited June 25 in Speakers
So I hooked up my new preamp and as I was listening and setting up, I’m hearing a solid difference in output between the 707s. When the balance is even, I’m clearly hearing the right channel higher. And even when I I shove the balance over 2.5-3 dB, they sound sort of even, but even the right still pushes more high frequencies. It’s driving me pretty crazy, truth be told.
I’m going to hook up a couple other sets to speakers to troubleshoot before I contact Polk. I’d rather not have to try and send one/either of them in, especially since both the boxes got relatively destroyed in shipping.
Is this sort of thing normal in production to have such a difference between units?
  • FestYboyFestYboy Posts: 2,654
    No, I'd be checking the bias on the preamp before condemning any speakers.
  • alucidideaalucididea Posts: 103
    edited June 26
    FestYboy wrote: »
    No bias switches on either amp or preamp. NAD M22/M12
  • DSkipDSkip Posts: 14,758
    edited June 26
    Check that all drivers are working properly. Also might not hurt to check polarity of each driver. The second part requires pulling drivers out so try another pair of speakers first to ensure it isn't the preamp. Actually, switch the speaker cables and see if the issue follows the channel or the speaker.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Reading the first post (to me) indicates that this issue only presented itself after the preamp was installed. If this is wrong, please clarify.
  • tonybtonyb Posts: 29,536
    edited June 26
    FestYboy wrote: »
    That's my take also.
    If the new pre is of substantial improvement over what you had been using, what your hearing may be just simply a better separation of instruments and imaging. Also placement of the speakers in relation to your listening position and room reflections can also give the illusion of one speaker being louder. I highly doubt it's the speakers.
    Check all your wire connections also.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • ClipdatClipdat Posts: 4,471
    Any updates?
    Got Dayens?
    Clipdat wrote: »
    Any updates?
    Sorry, none yet. I’ve been a little too busy to do a full troubleshooting with it all.
  • GospelTruthGospelTruth Posts: 313
    Sounds obvious, but did you switch the speakers and move the right one to the left and the left to the right? If the one speaker is still lower when moved, then you've isolated it to the speaker. If it's still the right channel, then it's your pre or room. Best way to see if it's the speaker though.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
    edited June 27
    So I tried switching the channels at the input, no help. I just switched the speakers a few minutes ago. In both cases it still leans to the right, so it’s not the speaker.
    If it’s not the speakers or the pre, it’s either the cables or room. Obviously I’m trying the cables next.
  • joecoulsonjoecoulson Posts: 449
    Room dynamics for me always changes the perceived output of each side. I have windows/Wall left and open right so it always sounds louder from the left side. I’m sure that’s obvious but...
    TV - Sony XBR 75X900E
    Amps - Marantz SR5003 (pre for 2ch) , 2 x Linn Lk240’s
    Speakers - POlk Lsim705’s ,Totem Acoustic Rainmaker's, Sonus Faber Piccolo, Definitive Technology SM350's , Sonos Play 5, 2 play 1's, Mirage Oasis MKii's
    Subwoofer - SVS SB16 Ultra
    Sources - Cambridge Audio CXN v2, Denon 2910, Sony CDP-CX355, JVC XM448B
    Vinyl - Project Debut III, Nagaoka MP-110, Cambridge Audio Solo, Okki Nokki RCM
    Cables - Zu Audio power cables, AudioQuest Type 4 speaker cables, Linn Interconnects
    I’m not positive, but I think I may just have some hearing loss in my left ear. Maybe one too many loud concerts or something. Guess I’m going in to get my hearing checked...
  • Airplay355Airplay355 Posts: 4,248
    Can you use a db meter app or db meter to test individual channels? Or, unplug a speaker and do it the old fashioned way :)
    edited July 1
    Airplay355 wrote: »
    Maybe. I didn’t even think to check for an app. I’ll have to look into that.
    I have a free db meter app just called db meter. Seems to do the job well enough. It's not something I would use to setup room correction software but maybe it will help you figure out if one speaker is a few db lower than the other. It's an iOS app but maybe there's an android version as well.
Howdy, Stranger!
