Can it be done
Has anyone ever taken the TL center channel apart? I think I broke the speaker post.
  • FestYboyFestYboy Posts: 2,874
    Picture please...
  • monepolkmonepolk Posts: 871
    I'll post some picture as soon as I can.
    Here are the pictures
    Ok, did some poking around, and it appears there are 2 options I see: the units are either sonic welded together (unlikely) or behind the grill post bushings are the attachment screws.
    Wish I had a better answer, but I've never had one in my hands.
    Thanks I'll check that out.
  • Airplay355Airplay355 Posts: 4,258
    What did you break and how'd you break it? Before you go cracking that open, maybe there's an easier way to deal with the problem you're having.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,651
    Remove the grille post rubber cups and you'll find the screws that hold the front baffle onto the enclosure.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
    Airplay355 wrote: »
    I had just got it back from my daughter and I was trying to remove the cap from the speaker post. Didn't notice the post was turning with the cap.
    Thanks, any suggestions on how without damaging them (the rubber cups).
    That's good, glad you could fix it.
Howdy, Stranger!
