Stello DA100 Signature. Anyone ever have this DAC
fbm211fbm211 Posts: 1,459
I just picked up one on ebay for 320.00. I figure it will be a little better than my Arthur v3 DAC since its a little newer. (And the fact that my Arthur is Dead.) Just curious if anyone ever tried it. I picked it because it has the type of i2s interface Ive been looking for.(The older DIN type connector) If the Dragon Pro does for the Stello what it did for the Arthur I will be more than happy. And maybe I can get long optical and usb cables to see how it sounds via my PC as source. Never tried that yet.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • fbm211fbm211 Posts: 1,459
    What a good little DAC. Better than the Arthur DAC without the Dragon Pro between the Arthur and Dragon Pro but not quite as good with the Dragon/Arthur combo.
    I did a sound test audition all afternoon with the Stello hooked direct to the Theta via AES/EBU. And then later hooked up to the Dragon Pro via AES/EBU in and i2s out to Stello. Some improvement but not as drastic as the Arthur/Dragon Combo.Probably due to the Stello being a more modern DAC.
    I did notice a deeper Bass right away as well as a wider soundstage. Highs were a little more laid back but not much. The upsample is a nice option to have but I did notice some songs sounded better while others I prefered bypassed.
    not a bad deal for the price and now I just need to get a 15 foot optical to see how the PC will sound on the 2CH Gear.le81ezol55ft.jpg
  • ClipdatClipdat Posts: 3,809
    @kharp1 has one of these.
    Got Dayens?
  • kharp1kharp1 Posts: 2,383
    I do have one. It hasn't been in use for some time, but, didn't really want to part with it. Capable unit.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • tonybtonyb Posts: 29,207
    Clipdat wrote: »
    What doesn't Kerry have ? The man's been on a binge since he found his wallet he lost in 1967. :)
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    PC sounds pretty good . I hooked it up with a 15 foot optical cable and was surprised at how good it sounded.And that was youtube.Later i will see how using the PC DVD drive sounds.Just wish my geforce card had a HDMI output for video. Anyone know if a DVI to HDMI cable wound work for video?
  • pitdogg2pitdogg2 Posts: 10,020
    fbm211 wrote: »
    yep
    Thanks.
    Nice Theta transport.
    Got Dayens?
Howdy, Stranger!
