Any real soundbars out there?
gwhgwh Posts: 1,396
Yep Google is my friend but it does return a lot of crap to wade through.
Interested in a passive LCR soundbar that is big up to 60 inches in length depth and height not a real issue since it will be sitting on a large piece of furniture/gear cabinet. Are there any with 5 1/4 or 6 inch drivers?. I've looked at some sound bases but those tend to be short in length.
Thanks,
G
HT:
Polk S60
Polk S35
Polk F/Xi3
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
  • DSkipDSkip Posts: 15,047
    I think the passive issue is going to be hard to get past. Most any soundbars worth a damn are going to be active since much of their strength is attributed to the programming done through the unit.
    It may not be what you are after, but I was impressed enough with the Mini to have no qualms suggesting you consider the Max SR. Maybe see if you can get your ears on it?
    https://www.polkaudio.com/products/magnifimaxsr
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • BlueFoxBlueFox Posts: 10,176
    I bought this Samsung to go with my 65” Sony XBR900F, and I love it. It is pretty cool how attaching an HDMI cable between it and the TV automatically switches the TV sound to the sound bar, and turns it on with the TV.
    Not sure what passive means.
    https://www.amazon.com/gp/product/B06XGWGVQG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • tratlifftratliff Posts: 655
    Check out the Yamaha’s. Not as big as you describe but I have been happy with mine. I have one in the living room and one in the bedroom.
    Legacy Focus SE, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Marantz SA-14s1, Oppo BDP-105, Technics RS-1500, Furman Elite 15PFi, Douglas Connection Alpha Interconnects, Douglas Connection Alpha Speaker Cables, Pangea Power Cables
    Theater
    Yamaha RX-Z9, Legacy Focus SE (same as 2 Channel system), Def Tech C/L/R 2500, Def Tech BP-2X, Def Tech Pro-Monitors, Vizio M-75
    Office
    Teac NP-H750, Parasound Ztuner, Audio Engine P4N, Grado SR80, Grado iGrado, Audio-Technica ATH-M50, PC running High Rez files
    Living Room
    Yamaha YSP-4100 digital sound projector, Sharp Aquos 60"
    Bed Room
    Yamaha YSP-5100 digital sound projector, Sharp Aquos 70"
  • mdaudioguymdaudioguy Posts: 4,697
    edited June 17
    BlueFox wrote: »
    Assuming he means a soundbar with no internal amplifier, so a receiver will be needed for power.
    Here are some options, although I don't think there will be many with larger drivers.
    https://goo.gl/MJsKvU
    EDIT: Link goes to Crutchfield. Original link did not play well with Vanilla.
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • TopperDudeTopperDude Posts: 54
    Look into some of the DefTech Mythos bars as well as the GoldenEar SuperCinema range
  • erniejadeerniejade Posts: 4,256
    For powered i was impressed with the polk maginifi max from what i heard at best buy. Not sure on non powered for sound bar only and not a complete HT rig.
    Lumin D1, KEF LS50 Wireless, Cayin scd-50T, LH Labs VI Dac, Technics 1200, Denon DL160, Jolida D9, HP I7 Laptop, Wireworld Eclipse 7, Wireworld Aurora, Wireworld Electra 7, Signal Magic Digital, Cardas Quadralink 5C, Velodyne SPL1200
    USB helpers: w4s Recovery
    HT: Elite SC27, Full Polk RTI setup.
  • gwhgwh Posts: 1,396
    Man that Goldenear SuperCinema 3D Array XL looks pretty sweet.
    HT:
    Polk S60
    Polk S35
    Polk F/Xi3
    SVS SB16 Ultra
    Yamaha RX-A3070
    gwh wrote: »
    its not cheap but if your looking for an awesome passive bar, its a pretty cool route to consider
Howdy, Stranger!
