2 Channel Amp to Atrium Sub10
I didn't have any responses from this post in Subwoofer Hookup so I'm posting here:
I'd always thought that a sub needed at least a five channel amp. But from what I read last night, in preparation for installing my outdoor speakers (a pair of Atrium 5's and a Sub10), it appears that I can use a two channel amp – one channel taking white/green and the other taking red/black with the two 5's wired per usual into those same channels. (The attached image is from Polk's manual for the Sub10/Sat30 combination.)
So two questions -
1/ Is this correct?
2/ Will my old Luxman R-115 (70w into 8Ω) do the trick? (Its specs are at https://www.hifiengine.com/manual_library/luxman/r-115.shtml) I'm not sure if the amp's 20Hz to 20kHz frequency response will be sufficient, or if it even matters.
Thanks!
Hi-Fi
Apple Lossless --> Squeezebox Touch --> Joule Electra LA-100 Mark iii --> MIT AVT2 IC's --> Adcom GFA-555ii --> MIT EXP S2 Cables --> LSiM-705's
Visuals
http://StretchPhotography.com
  • F1nutF1nut Posts: 39,969
    Polk published it, why are you in doubt?
  • txcoastal1txcoastal1 Posts: 9,774
    In his defense "measure twice cut once"...besides, you know from early builds, some things were never the same
    @stretchl
    It may look funky, but it is pulling the left and right channel signals into the sub
    If you had (2)-subs then you would go
    grn/wht to left chnl sub
    Red/blk to right chnl sub
  • stretchlstretchl Posts: 887
    Thanks. Tx.
    Hi-Fi
    Visuals
  • oldrockeroldrocker Posts: 1,827
    Hey stretch,
    If you don't mind once you get it all up and running, let me know how it sounds as I need some more outside bass myself..
  • JaybeezJaybeez Posts: 677
    I have that sub but always suspected I hooked it up wrong. Curious to know how this works out.
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Rythmik F12SE
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
    oldrocker wrote: »
    Hey stretch,
    @oldrocker I certainly will. I hope to test the set up in the next couple of weeks. Need to wait until we get the house painted (a few more weeks) before I actually install the speakers.
    Hi-Fi
    Visuals
    Jaybeez wrote: »
    JB, I’ll let you know.
    Hi-Fi
    Visuals
    edited June 14
    stretchl wrote: »
    Jaybeez wrote: »
    Thanks! JB is actually my nickname. Even my wife calls me that.
    I go with Jaybeez on forums as Jaybee is taken already on most of them.
    Thanks for the updates whenever you get around to it.
    BTW, love your website. My wife is a photographer. At West Coast School as we speak.
    Love your emoji here! :)
    Hi-Fi
    Visuals
Howdy, Stranger!
