sub no sound
the lights are on but no ones home...
Sub works for test tones from receiver but produces no sound during regular watching or listening. have tried all the settings any thoughts?
thanks
  • tonybtonyb Posts: 29,059
    Need more info....what sub ? How's it hooked up and to what ? Are you playing material that has low freq. sounds ? What settings are you using on the sub...receiver ?
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • lucifershandlucifershand Posts: 3
    sub is psw111 off of pioneer vsx-831 subwoofer cable lfe
    i have played all sorts of different material through the sub sub is set to on 0 phase dials around half way up on each and have cycled through what id say are all of the settings on the receiver ive been trying to figure it out for a couple of weeks and am out of ideas
  • KennethSwaugerKennethSwauger Moderator Posts: 6,404
    To test the subwoofer first turn the sub's volume all the way down and remove the sub cable from the receiver. Then connect the sub cable to either the right or left audio output of your DVD/CD player and begin playing a CD and slowly turn up the volume on the sub. It should make plenty of bass at a low setting.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
Howdy, Stranger!
