Magnifi Max and Apple TV 4k audio
I'm having a weird phenomena that I can't seem to find anywhere, when I play content on my Apple TV 4K, it always takes about 8-10 seconds for the audio to start even though the video starts right away.
My other devices don't seem to have this issue (Computer and PS4). Obviously that may point to the Apple TV, but given that the Magnifi has other issues, I thought I may want to check with this group first. Any ideas?
  • mlistens03mlistens03 Posts: 986
    Look through your settings on the Apple TV and see if there is a “lip sync” setting. Then see if it’s I still 8-10 seconds off of where it should be, and set I think to where it should be. If it isn’t set incorrectly, see if adjusting it makes a difference and then if it does see if you can adjust it enough to fix the problem.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • PolkHeroPolkHero Posts: 5
    Thanks for your reply. It's not so much a sync issue (which I hear is an issue on some TVs) as it is just taking 10 seconds to start.
    PolkHero wrote: »
    How is it set up? Apple TV -> SoundBar -> TV? Apple TV -> TV -> Soundbar?
    If it’s is the second option, it could also be your TVs problem.
    Also, does it take ten seconds to start from first turning on? Or after turning on a TV show? If the latter then my guess is the Apple TV is the culprit, if the first then it could be anything.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • robertmarkrobertmark Posts: 0
    You need to remember the settings which you can solve the audio issue. It is nothing but some settings issue that can be solved by doing some changes in the settings. When I used to connect my Dell laptop to the Apple Tv 4k then this problem also arose as the video of my laptop played well in the Apple tv 4k but the audio did not come. I got the help from Dell tech support
    Gotcha, I could try Apple support. I looked around their forums but didn't find anything, so wanted to ask ya'll.
    My set up is Apple TV > Sound Bar > TV. It happens regardless of how long the bar has been on (not just a first-power on thing)
Howdy, Stranger!
