Hum noise
jumpindickjumpindick Posts: 202
Hi Ya All,
Happy Friday and very happy (I hope) weekend. Forgive me if this has topic been here for a few times. I tried to find answer by going through the previous posts, but could not get clear understanding. So thought to post.
I have been noticing an annoying hum noise in my HT system. The processor is Marantz AV7702MKii. All sources are connected to the processor including cable box, roku and blue ray player. The power supply is through Belkin power conditioner to which power plug of two amps are connected as well.
The humming noise was really annoying. So I started to take off the sources one after another in order to understand where it is coming from. Unplugging them did not help. Then I started to disconnect the HDMI cables, one source at a time. And the cable between the cable box and processor did the trick. This HDMI cable is not what the cable company provided, but it is a bluejeans cable. The same type of cable is also connected between roku and the marantz processor, but I do not see any humming issue from roku.
So, what can I do to solve the cable box hum. One option is to disconnect at times when I am not watching the cable. But that is kinda pain in the rear.
Any suggestions??- I was thinking to try another HDMI cable and see what happens.
  • kharp1kharp1 Posts: 2,315
    I've seen where the cable box has been the culprit in several hum cases.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • Yep2Yep2 Posts: 1,087
    edited June 1
    Maybe it was humming cause it didnt know the words.
    Try another HDMI cable.
    Ive had the WORST luck with HDMI cables!
  • mpitogompitogo Posts: 249
    edited June 1
    Does the Marantz pre have a 3-pin IEC connector with ground? If not it may be a floating ground. Cable companies always (typically) grounds their coax to earth and you likely have a ground loop. You can look it up but basically there is a difference in potential between the two components’ ground. Try connecting the cable box ground if one exists or a chassis screw to the receivers ground if a phono input exists. All of the components should reference the same ground. The cable box is carrying earth ground on the shielding bringing it into the box and the box may only have a two pin power connector.
    Does the Belkin power conditioner have a grounding screw? You can reference this for all components with a chassis ground if they don’t use a standard IEC 3-pin C13-C14 to 5-15 power cable.
    Music-2.0 Raidho D-3.1 | Audio Research Ref 40 | Jeff Roland 925 | Esoteric Grandioso K1 | Transparent Reference, IC, Speaker and Power | HRS SXR Rack
    edited June 1
    Every component has a "potential difference".
    edited June 1
    Any "wall wart power supplies" in the system?
    Yep2 wrote: »
    There's a difference between "every component have potential differences" and the ground potential difference causing a hum.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
  • Mr. SharpeMr. Sharpe Posts: 1,077
    Hey buddy, when I unplug my cable line from the box my Him/buzz will stop, if the wire touches the box it will start. I second the ground loop. Same thing happened at my parents old house and it made me so mad bc I couldn’t listen to music without hearing it.
    Marantz UD-7007 Cd Player
    Parasound Halo P5 Preamplifier
    Marantz ST-7001 Radio Tuner
    Parasound HCA-1500A Power Amplifier
    Polk Audio Monitor 10B's
    5 channel
    Sony Bravia 32" LED
    Yamaha RX-a3010 Receiver
    Marantz UD-7007 Blu-Ray player
    Klipsch RB-61 Main Speakers
    Klipsch RB-41 Surround Speakers
  • jumpindickjumpindick Posts: 202
    I agree that it can be so frustrating. Those cable boxes are cheap... I am in the process of getting another one (not sure if that will help) and see if anything changes. If not, I will have to look for another way to stop the humming noise and still use the cable box.
Howdy, Stranger!
