PSW505 humming and no audio
I just bought 2 of these and out of the box all I get from either is humming. All the switches and knobs seem to be working properly but once anything is plugged into the audio in ports they just hum loudly and don't respond to audio being sent. I tried plugging it into a different outlet than the receiver and I tried both the filtered and unfiltered ports. The receiver is an Onkyo tx-nr575 and I have used a sub with it before with no problems. Am I doa on this or not trying hard enough?
Answers
  • ken brydsonken brydson Posts: 7,007
    Have you tried a different cable?
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • tsobecktsobeck Posts: 3
    I have tried 4 different cords and none seemed to change anything
    Odd that both subs have the issue. Can you return them?
    I hadn't looked into it yet because I was hoping by some grace there would be a solution considering it was both, but that was going to have to be the next step
  • jeremymarcinkojeremymarcinko Posts: 3,030
    Sounds like a ground loop hum. Try plugging them in at the same location as the avr. Does the humming quit when the source cable is removed?
    Or, try removing other components and add them back to see if the issue persists or subsides. Cable box’s are usually a good place to start.
    Or try going the other direction with the source cable.
  • FestYboyFestYboy Posts: 2,521
    2 units with the exact same symptoms points to something other than the units.
Howdy, Stranger!
