Cooling fans work/ help?
KingkwasKingkwas Posts: 68
edited May 27 in Electronics
Do cooling fans help increase performance?
https://www.amazon.com/AC-Infinity-Top-Exhaust-Receivers-Components/dp/B01LW1Q4X9
Played Fury tonight on a 4k disc. Swear that by the end it didn’t sound as good. Less punch. Afterwards when taking out the DVD, the Marantz was hot to touch.
Thoughts?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • BlueFoxBlueFox Posts: 10,127
    edited May 28
    Excess heat is the enemy of electronics. I doubt if the fan will hurt, and might help. The issue I have with cooling fans is my hearing is pretty good, and the fan noise between songs, or in quiet passages really annoyed me.
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • EndersShadowEndersShadow Posts: 15,927
    edited May 28
    I have two of these, both S8s. One on top my Denon X4100, the other on top my B&K. I am thinking about one for my Xbox One to help as well
    These run super quiet and you can program them to be one speed, or increase as the temp rises.
    All with a couple button clicks.
  • steveinazsteveinaz Posts: 18,396
    Many component cooling fans now have adjustable voltages to minimize fan noise. I ran mine at 6.5volts and could not hear it, even when right on top of it; and it kept my HCA-1500 bacon fryer cool.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; Belden 1694A Dig Coax | AC Power: Panamax M5300-PM
    edited May 30
    @steveinaz I liked the way yours looked too, and it can hold more weight than these. I think your not supposed to put something more than 30lbs on it, which in my case means my AVR barely would work on top it (if it would actually fit in the unit like that).
    In this case, the little button with a fan logo on it (right side) actually indicates if the fans are running, and if so at what speed. You can set it to just let them run 24/7 at a given speed, or let it go to automatic where it will ramp up as the temp ramps up (which is what I have it set to).
    At top speed they are VERY LOUD. Mine tend to stay at whisper quiet though if I'm getting ready to run my Audyseey XT32 calibration (during which I kill breakers to the fridge, AC, fans, etc) then I can hear it, but thats a very rare thing.
    Wish I could remember the brand....hmmm...yes the build quality was nice, and the paint finish looked just like my amplifier texture/color. I sat mine on top to draw hot air up and out (through the internal heat sinks).
    steveinaz wrote: »
    Cool components :smile:
    Here is your review thread on it (read it a few times perhaps :wink:)
  • mpitogompitogo Posts: 281
    edited May 31
    The fan looks to have been designed for Marantz. I suggest active cooling to help with longevity. Mine used to get very hot, I bought one and I’ve set the fan auto temp to turn on and adjust speed based on heat output of the receiver. The fan always turns on after a few minutes but never gets out of the lowest speed. It’s also a great match style wise.
    Music-2.0 Raidho D-3.1 | Audio Research Ref 40 | Jeff Roland 925 | Esoteric Grandioso K1 | Transparent Reference, IC, Speaker and Power | HRS SXR Rack
  • zeppage2zeppage2 Posts: 159
    edited May 31
    Thanks to this thread, I picked one up (AIRCOM T8) through Amazon.
    I am interested to see if it will survive atop a Rogue Atlas Magnum ll with a tube cage/cover.
    Even if it does it will still likely run very high and possibly loud, but it can’t hurt to try...
  • mrlorenmrloren Posts: 1,469
    I have one of the Aircom on top of my bedroom SR5010. The TV stand it's in doesn't have very good ventilation so I added one. Before I added i after 30 minutes of light use it was hot enough to cook an egg, now nice and cool.
    I set the fan to auto, I can't hear it till it's over 3/4 and then it's not very noticeable
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • jimbo1421jimbo1421 Posts: 761
    I just set up a pair of AC Infinity Aircom S8's. I find that the half speed setting is just audible at 8' during quiet passages. I am still tinkering to see if it needs to go to 3/4 speed to stay below 88 degrees.
    5.1 System:
    Sharp Aquos 37" LCD
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    NAD 106 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • gudnoyezgudnoyez Posts: 6,325
    I paid $30 for 2 little usb powered fans that pulls the heat up and pushes the heat out. I can watch movies at reference levels for hours and the old Onkyo AVR stays cool as a cucumber.
    gudnoyez wrote: »
    I started with doing that, but these coolers work better and are nicer because they are fully automatic.
    Double the price of what you paid, but IMHO worth it. I'm even tempted to get one for my XBox One
    edited June 2
    No doubt the one you got is a good one,, the next one I get will be one of those. I have a Denon that I could move my old ones to, the Denon not used that much, but can get pretty warm when it's been running a while.
Howdy, Stranger!
