Stainable Wood Filler
kevhed72
kevhed72 Posts: 4,958
I am staining our deck and already tried 2 type of wood fillers for screw holes and imperfections. Both trys yielded a much lighter color of filler than the stain itself....what am I missing here???
    F1nut Posts: 49,794
    Filler never takes color the same, mainly because it's not wood. Using wood plugs with the grain going in the same direction would get you closer, but what a PITA.
  • kevhed72
    PITA should be printed on the can of wood filler. I know someone who claimed there is a special filler to be stained over but I cant find it!
  • Mikey081057
    Mikey081057 Posts: 7,127
    Just use pieces of old underwear.... That seems to hold stains
    Garage | Polk Monitor 5B's
    F1nut Posts: 49,794
    kevhed72 wrote: »
    There isn't a filler made that will take stain exactly the same as wood. Even different boards of the same wood species take stain differently.
  • mrloren
    mrloren Posts: 2,454
    even if you countersink the screws 1/2 way down and use a dowel it will stain different. I've tried many different fillers from Elmer's to some stuff that cost $30 for a small can, all were about the same.
  • kharp1
    kharp1 Posts: 3,453
    Just take a chain, a hammer, some gravel and other odds and ends, and, distress it. Then no need for filler :)
  • bikezappa
    bikezappa Posts: 2,463
    Stain the wood first then match the wood filler to the stained wood.
  • ken brydson
    ken brydson Posts: 8,648
    Not sure why you'd want to fill the screw holes. It'll be a beotch when/if you need to replace any boards... JMHO
  • kevhed72
    Thats a great point....but too late!!
    I tried hitting the filled spotts will drops of stain and let it sit a bit before brushing it in. Then went back and stained the entire board. It worked better but not great. I went overkill with filler and stain on the stairs since this area will take the brunt of traffic and the sun. Ill post pics tomorrow but I must get this done before the dog days of a SW Georgia summer.
  • kevhed72
    bikezappa wrote: »
    Home Deblow recommended mixing stain with this stuff to color the filler....I poured alot of stain in here but it was still way too light. jh1b885ohzon.jpg
    F1nut Posts: 49,794
    Key word on that can, PLASTIC.
  • BlueFox
    BlueFox Posts: 15,251
    LOL. Best advice yet.
  • kevhed72
    Yesterday we had perfect weather and then it rain overnight. I’m moving on to the rest of the deck this morning and will go back to hit the lighter areas when it drys out here. That can of wood filler is getting returned.
    F1nut Posts: 49,794
    edited May 2018
    I wouldn't use Gorilla glue on anything, terrible product.
    Mixing saw dust with wood glue is pointless because in the end it's still glue without the grain or pores of real wood and therefore will take the stain differently.
    There are ways to match the color and the appearance of grain in real wood, but it requires specialized materials and a lot of practice.
    F1nut Posts: 49,794
    edited May 2018
    Maybe in your world it looks ok, but in mine it looks like someone didn’t know what they were doing. No offense to you.
    Gorilla glue is polyurethane based and requires moisture to cure. Because of that as it cures it foams creating air bubbles. Air bubbles in glue create a weak bond. Therefore, it is a terrible product.
  • Mikey081057
    I wouldn't sniff no gorilla glue..
  • Mikey081057
    Aren't you a deck wit!
  • Mikey081057
    edited May 2018
    I think you have drank too much deck juice....
    nooshinjohn Posts: 25,094
    kevhed72 wrote: »
    You will find Liquid Wood right next to the black paint... I understand it can also be found in those stores that sell toys for bedroom use.
  • BlueFox
    kevhed72 wrote: »
    Amazon has all that, and more. :)
    F1nut Posts: 49,794
    Yep2 wrote: »
    Gorrila glue is polyurethane based and requires moisture to cure. Because of that as it cures it foams creating air bubbles. Air bubbles in glue create a weak bond. Therefore, it is a terrible product.
    Its a deck.
    I mentioned the sawdust/glue as an option.
    Glue is secondary, and again, a personal preference.
    Bad advice is still bad advice and yours is bad advice.
