speaker baffles
i need help i got speaker baffles for some cheap aftermarket speakers because it came with the head unit but i just upgraded to the pionner a series speakers and idk if i should keep the baffles or take them off and the boom mate speaker baffles 2 6.5 and 2 6*9 and i have a 05 toyota corolla
  • exalted512exalted512 Posts: 10,794
    If your doors and rear deck are sound deadened, definitely remove the baffles. If they're not, it's kind of a toss up. Car audio drivers are made to work in an infinite baffle setup, but all the holes in a door/rear deck causes it not to be a true IB setup. But foam baffles aren't exactly great enclosures. Thought about trying it both ways before you put the panels back on to see what sounds better to you?
    -Cody
Howdy, Stranger!
