alternator
i have a 05 toyota corolla and im putting a sound system and i need to upgrade the alternator but i cant find any high end output one online can someone help me please find one
  • codycatalistcodycatalist Posts: 1,435
    First I would post in the mobile audio section. Second I have a dual amp system in my 09 Corolla and I would advise to probably just run an separate battery. The stereo although not pulling a ton of wattage puts a pretty big strain on the car.
    If you do want to run a HO Alternator I would also advise to upgrade the "Big 4" to allow the current to run freely. Have you done any calculations to see how many amps you will be pulling?
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
  • Yep2Yep2 Posts: 1,125
    Find an "Alternator" rebuild shop in your area (there are "A Bunch" online also).
    They can build anything you want (and give advise).
    Extra battery is only good when your vehicle is NOT running.
    Upgraded alternator is the way to go (your engine benefits also).
    I went from a 105A stock, to a 140A & the difference was night & day.
    A 2 battery charge controller is the cost that sux.
    I had 2 batteries (not for audio reasons) on my First Gen Yota 4 Runner & ended up buying 3 controlers over a 1 yr period.
    Optima Yellow Top & upgraded Alternator solved my problem & put a smile on my face (running 2 amps).
  • First I would post in the mobile audio section. Second I have a dual amp system in my 09 Corolla and I would advise to probably just run an separate battery. The stereo although not pulling a ton of wattage puts a pretty big strain on the car.
    ill be drawing about 100 amp and my alternator in the car is 80 amps so im looking at least 150amp alternator
  • Yep2 wrote: »
    i havent been able to find anyone
    edited May 24
    Online.
    Google "car audio alternator", cant miss em...
    Shipping is minimal on a single alternator.
    They can build a 200A if thats what you want. :p
  • littleasome14littleasome14 Posts: 8
    edited May 25
    FestYboy wrote: »
    thats weird i tried and it didnt show anything all i kepted getting was your car not supported
Howdy, Stranger!
