Sprout100
tonyb
tonyb Posts: 32,902
https://www.psaudio.com/sprout100/
Little booger is loaded, and for 600 bucks looks to be a bargain for all you get.
    mhardy6647 Posts: 32,926
    edited May 2018
    [EDIT] FWIW, here's Stereophile's take on the original Sprout:
    https://www.stereophile.com/content/ps-audio-sprout-integrated-amplifier
    FWIW^2 here is a photo of the innards of the original Sprout.
    Post edited by mhardy6647 on
    edited May 2018
    [EDIT] ... it says "vinyl" on the front panel :#
    tonyb Posts: 32,902
    Ya know Doc, for a reviewer in such a prestigious Audio mag. to be using Radio shack USB and IC's, one has to wonder about the validity of his review. Granted, he switched out cables eventually to AQ, but just the fact he's reviewing gear with Radio shack cables throws up red flags for me.
  • miner
    miner Posts: 1,305
    Nice little package which would be perfect for an office system.
    It is a nice little all in one package, isn't it?
  • erniejade
    erniejade Posts: 6,288
    Kind of like the ELAC EA101EQ-G
    Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
    erniejade wrote: »
    Of which I knew nothing 'til you mentioned it! :p
    https://www.elac.com/product/debut-series-da101eq-g-integrated-amplifier/
    It is interesting that the manufacturers (distributors) of these sorts of amplifiers spec only 1kHz THD. The Stereophile review of the original Sprout was somewhat revealing (although the undefeatable LF boost of he original morph of the Sprout sort of complicated measurement thereof).
    It is a plus that the LF boost is defeatable on the new and improved Sprout 100 :)
  • kharp1
    kharp1 Posts: 3,453
    I really like what PS Audio is doing these days. Like the products, though I haven't heard this piece (the Sprout is what Paul, the owner, uses at his home) and their customer service is incredible.
  • mrbiron
    mrbiron Posts: 5,711
    Still wish i didn’t sell my “original” sprout but feel the $600 price tag is pretty steep for this product. The volume control vie remote is nice this time around.
    mrbiron wrote: »
    I did not know (or, more likely, did not remember :p ) that you had had a Sprout!
  • mpitogo
    mpitogo Posts: 475
    edited May 2018
    Nice tidy little integrated.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • kharp1
    kharp1 Posts: 3,453
    mrbiron wrote: »
    You're kidding, right? $600 for 100 wpc, asychronous DAC with it's capabilities, variable sub output, phono stage, built in Bluetooth...
    Sounds like a nobrainer to me.
    I read this someplace else, and strictly FWIW:
    ... TEAC AI-301DA. Same B&O amp module now, similar feature set. Sprout100 has onboard phono and pre-outs. AI-301DA has additional line and digital coaxial input , and can be had ~$300 cheaper [than the Sprout 100]
    Thoughts?
  • indyhawg
    indyhawg Posts: 1,633
    I have always been curious about how the TEAC compares to the Sprout.
  • Moose68Bash
    Moose68Bash Posts: 3,842
    The two most obvious differences between the two are:
    1) The TEAC is only 22W into 8 ohms, and the Sprout is 50W.
    2) The Sprout has a phono ["vinyl"] input and the TEAC has none.
    How they might compare in SQ is another issue.
  • mpitogo
    mpitogo Posts: 475
    I would probably say Elac would be a close competitor can be found under 600, close to the sprouts 599 price point.
    Elac vs Sprout
    Pros:
    Offers sub blending room EQ.
    More inputs,+1 Optical, +1 Coax, +1 RCA
    Cons:
    Less power (40wpc 8ohms)
    No phono input
    No preamp output
  • erniejade
    Elac is supposed to be coming out with a version that also has a built in streamer, it all depends on what your needs are.
    The Sprout is great for the money especially if your into LP.
  • kharp1
    kharp1 Posts: 3,453
    edited May 2018
    I had the Teac at one point thinking it was a no brainer at that price. I couldn't get past the terrible sound quality and sent it back. Owning a PS Audio Directstrem DAC, I can say I like what they do with that DAC. I'm not sure how that translates to their use of the Sabre chipset, but, I'm hopeful given what they've been doing with their other pieces. Hopefully they'll run it for $499 during the holidays, again, and I'll grab one for the kitchen/coffee shop.
  • erniejade
    Correct. 100 per ice power Elac is 40 per class AB
  • kharp1
    kharp1 Posts: 3,453
    erniejade wrote: »
    The streamer aspect is interesting, going to keep an eye out for that.
  • indyhawg
    kharp1 wrote: »
    That was my concern. I am curious of what the sound quality will be with the Sprout. It looks like it has potential to maybe go into an office set up I am going to do in the future.
  • mrbiron
    kharp1 wrote: »
    No, i’m Not kidding, and you just made my point.
    $499 is a better price for this particular piece. That is was i bought my original sprout for and it came with an AC3.
  • kharp1
    kharp1 Posts: 3,453
    I was already questioning your line of thinking and rationalizing my last statement makes me wonder even more. You went from inferring it should be priced like the Teac to saying I prove your point by hoping for $100 off on a holiday sale makes no sense. I'd buy it at its price point as I feel it offers a great value. I don't need one at the moment or I would buy it at this price. When my house work gets done I'll probably have a perfect spot for it, and on sale or not, it'll be what I get. Hoping to save $100 if it's on sale in no way proves your point.
    I believe it offers a great value from what I can see and know about the company from previous experience.
    EndersShadow Posts: 17,517
  • The Sprout nails looks and versatility. And all the reviews I've read agree it nails sound quality. I need a remote so the S100 is the complete package.
    I just want to get a line on the SVS SoundBase when it comes out in the Fall. Might be good completion.
    HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
    BR: iPad Mini, Audio Engine A5+
    2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
    Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
    Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
