Polk 7A midwoofer question
Greetings, new member here. Apologies for being long winded a bit here...
I just bought a pair of 7A's, serial numbers are 03049 and 03093 so pretty low I think. The mids have the Masonite rings on them but when I pulled them out to see what version there was no identifying marks/labels on the back. One did have "SKU 132" and "557" and "708" written on them in marker.
I noticed after I had them all hooked up that one of the mw's has a clean rip/tear in the rubber surround. Temporarily I've brushed some super glue over it, which seems to be working fine.
Anyway, what is the recommended replacement mid-woofer for 7A? I didn't remove the wires from the mid when I had it out (they're soldered on) but when I check resistance from the speaker wire plugs, the entire speaker measures 7.5 - 7.7 range.
All I am thinking is I need to stay away from the 6502s because they were 4 ohm. 6500's or 6503 is what I'm thinking from reading here.
Do the Masonite rings really do anything? Could it be moved to a new mid if I get one that doesn't have it? I get kind of anal about things like this, and if they didn't match on both speakers I would obsess on it....
Also, I was thinking I would replace the caps on the crossovers, but they sound so good right now I'm afraid to mess with them. (I have a pair of Elac B6 bookshelf speakers also hooked up and switch between the two, so that's all I have right now to compare.)
On a side note, years ago I had some black SDA 2B Studios and got rid of them like a fool - wife didn't like seeing big speakers. Just like I got rid of all my albums for CDs, which I'm buying them all back on vinyl now....I'm back looking at vintage Polk. Love them.
Thanks for any insight.
    pitdogg2 Posts: 24,556
    edited May 2018
    Mw6502 is the correct driver for all models from what i see.
    They are plentiful you should not have any problem acquiring them.
  • westmassguy
    westmassguy Posts: 6,850
    edited May 2018
    Early Monitor 7s and 5s had MW6500s. The ring on the front is a fiber gasket, not Masonite. It serves no purpose for front mounted woofers.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • tjw141
    tjw141 Posts: 9
    Thanks, didn't think that ring/gasket did anything but wasn't sure.
  • Gardenstater
    @westmassguy - I have Polk 7B's, serial 197xx. Would this be the MW6502 or the MW6500? I may need to replace one of them that has been *chuffing* a bit every once in a while, on challenging music. Thanks.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 49,794
    Take the driver out, the model is printed on the rear of the driver.
  • Gardenstater
    Thanks. It's the silver frame MW6500 manufactured 1979. Bought a black frame NOS Polk OEM MW6500 on eBay since there are only used silver frame one's apparently, although if I ever find a NOS one I will snatch that up.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
