Signa S1 not working
Jdc1
I hooked up this sound bar and it works fine on the TV but when i switch to watch a blue ray i get no sound. I have used the small cable hooked directly to the TV and my Blue-ray player is hooked up to the TV with HDMI cable. Let me know if there is something that i can do to make this work.
Thank you
Thank you
What format are you sending out on the blu-ray player? It could be that you need to adjust the setting on it to send the audio out over HDMI differently. It also could be a audio setting in the TV that you need to adjust to make sure its passing the signal right as well."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
