DIY Speaker Cables / Connectors
alucididea
in Electronics
So I’m putting together my own speaker cables and looking for some decently priced connectors. I was looking at some Furutech hardware (FP-201R & FP-202R), but I don’t really think I want to spend almost $300 to terminate my cables. Does anyone have any experience with either Vampire Wire or Viborg connectors?
Needing 8 spades that fit 14ga wire and 4 banana plugs that fit 8ga wire. Any suggestions would be appreciated.
Contact Doug at Douglas connection and see what he has. He is a member here and can help guide you.
Email him he offers a discount to members here. Give him your handle here and what you are looking at.
I don't want to turn this into another power cable thread but IMO speaker terminations are for CONVENIENCE not for improving sound. Yes I know bare wire leads can eventually oxidize and potentially screw up the sound........so cut off one inch a year! Hook the shiny new wires directly to the speaker post. Thats as good as it gets. Why hook the shiny wires to another connector that will eventually oxidize too (but you can't see it so you think its good). It seems to me that unless you are constantly swapping components daily or weekly, for $300 I can live with a little inconvenience.
If you don't want to spend $20 per spade for the Futuretech terminations how about $2 per (shipped). I know the $20 ones are rhodium plated and alpha copper (whatever that is) but you can slum a bit and just get gold plated regular copper.
https://www.ebay.com/itm/10-Pcs-Red-Copper-Speaker-Cable-Spade-Connector-Terminal-Plug-Adapter-USA/173107810577?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Ok guys I have my asbestos pants on and just popped a beer.............let me have it.
Post edited by delkal on -
Bare wire sucks. Besides after removing an inch a year for 10 years at each end you've lost 20 inches!Political Correctness'.........defined
President of Club Polk -
Hey now, all this talk about losing inches is not allowed, not now, not ever. Gotta go hug my buddy now dang it.HT SYSTEM-
lsi 9's -
I didn't pay $300 for 20 inches of speaker wire...........
OK, You really don't have to cut off an inch or do it every year. So lets say a squirt of deoxit and a reconnect every year. Then cut off a bit every 5-10 years. You should probably do this for any termination you put on anyway unless it is soldered and shrink wrapped.
Why do you think a bare wire connection sucks? Is it just the potential oxidation? -
Included are some pictures and some info:
Pair of bi-wire cables just about 5m long
Each cable consists of 8 strands of 14ga OFC
Simple Parallel geometry
All I have left to do is attach connectors and put my big sheath on and I’m ready to break these in.
Connecting LSIM 707s to an NAD M22
alucididea wrote: »Each cable consists of 8 strands of 14ga OFC
Got your email Jason and will get back to you in the morning. That's some big speaker cable you are making! 8 strands of 14 gauge wire equals 5 AWG.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »alucididea wrote: »Each cable consists of 8 strands of 14ga OFC
Shoving wire inside the hole of a binding post isn't the best connection due to lack of contact area. High quality bananas have more contact area. Insert the wire into the open end and use silver solder to make the joint. Then apply adhesive heat shrink to seal the joint.Political Correctness'.........defined
Never though about sealing the jointMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Check out Blue Jeans Cable for connectors. They have nice quality low cost models. BJC also uses ultrasonic cold welding to fuse bare wire on to their spades or plugs when you buy their cables. It’s pretty neat.
Bi-wired with ~5ga effective total.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
@alucididea yes 8ft Canare 4S11 Star Quad black jacket with 45deg spades on both ends bi-wired to RB-1590 and LSiM707.
alucididea wrote: »@alucididea yes 8ft Canare 4S11 Star Quad black jacket with 45deg spades on both ends bi-wired to RB-1590 and LSiM707.
No....it's almost impossible to overpower a speaker. Amps don't throw out their rated power as soon as you turn them on. Amplifiers store power, for when needed. Like always though, you need to concern yourself with that pesky volume dial. That's where people usually run into trouble.HT SYSTEM-
lsi 9's -
you are FAR more likely to damage speakers by using under powered gear from clipped signal's. That is where the real damage occurs. Better to have too much power than not enough as you're not using all the power all the time. you'd be hearing impaired pretty quick.
Just because an amp can produce 1000 WPC as TonyB said that is not happening unless you bury the volume knob. That is why there is such a thing. -
Make sure you use the larger spades; many speakers, including my PSB's have the larger diameter binding posts. This will make your cable upgrade-proof.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
