PSA Veneer Sourcing
Going to be starting my M7c overhaul in the near future. Waiting for @westmassguy to finish my upgraded TL X/O’s. I’ve got the new RD198’s, Blackhole 5, Dynamat extreme, Armacell tape, Capped SS Allen head bolts & H- nuts. Think that’s everything except the cabinet refinishing itself. My plan is to veneer 4 sides (incl. the front) & attach a modified grill w/ magnets. Where is everyone getting their PSA backed veneer from? Most places I’ve contacted won’t ship to Alaska for some reason. It’s just a box of wood, I don’t understand the issues. Anyway I’m looking for some more sources to try. Any suggestions would be greatly appreciated. Also need to find out about the recessed magnet attachment for the grills, I’m not familiar with them.
Carver M1.0t, M200t, C2, TX2
Rega Brio, Cambridge 351C, Pro-Ject Acryl TT
Polk SDA 2a's, M7c's w/ full TL upgrade, M4a's
Klipsch KG4's, KG1's
  • westmassguywestmassguy Posts: 6,100
    edited April 19
    https://www.ovisonline.com/?gclid=CJWS4qDTh6YCFaE65QodLmt0ug
    I get my Quartered Walnut from them. If you're going Walnut, the Walnut Edgebanding is a perfect for the front edge.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • ThomasDThomasD Posts: 147
    Thanks David, I must have missed their site. I’ll contact them.
  • MrBuhlMrBuhl Posts: 2,308
    I've bookmarked this thread as well - anyone have a good source for PSA backed but figured veneers? Thinking ahead to my CRS 4.1TL's - I'm likely going cherry but really like the more figured look vs. quartersawn. Thanks! (sorry to thread-jack)
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
    MrBuhl wrote: »
    Hey, I'm with you. I love the 'figured' veneers too. I'm just looking on @westmassguy suggested site, Ovisonline.com & Veneerfactoryoutlet.com. I'm leaning towards the Rosewood options but not finding edge banding to compliment. There have been some incredible speaker veneer projects on this site. Hope some more 'chime' in and link pics of their projects.
    I really like the 'Santos' Rosewood veneer on the Ovis site. Seems all my favorites are not cheap ($200 a 2'x8' sheet) & out of stock. And most have a 2 sheet minimum. May just have to bite the bullet and place the order. Shipping isn't too outrageous for Alaska, $65 for parcel post. Order would be pending until new shipment of item is available anyway. Hmmmm..........
    Oh man - I didn't even think about there being minimums on that stuff. Yikes!
    Yes, there have been some great veneer projects on here, like you, I'm not afraid to spend a little coin to get a great veneer, but I am afraid I'll screw it up LOL. I want these 4.1TL's to be permanent "keeper" SDA's - so I want to do them right, and the exact way I want if you know what I mean!
    Good luck with your project - can't wait to see some pics when you get working on it!
    Polk SDA1c modded
    Yamaha YP-D6
    @MrBuhl I understand completely. At my stage in life I'm looking for 'end game' projects that will last. Don't have the time & patience to cut corners and 'get it right the next time'.
    I've only got a pair of M7c's & SDA 2A's right now but I'd like them to eventually be 'signature' pieces for my small collection. Ovis does have quite a selection of 'exotic' veneers.
Howdy, Stranger!
