Need advice on Best Center speaker to pair with RTI-A5's
Room Size 14x14
Currently I have the RM6750 as my surround speakers don't have a problem with them.
Rti-A5s 10.5" away from main seating area
Center same. The Center channel is the RM6750 currently & is way under powered..
There is a Sub in the Mix as well. It's the RM6750 8" Sub not the best i know but at the price I got the 5.1 system "dirt cheep".
Don't care on price I just want it to sound correct. I've read through the forums CSiA4/6, had one person say the S35?
There is no External AMP currently, I do want a 3 channel AMP to power the front stage.
  • F1nutF1nut Posts: 39,303
    You want a CSi A6.
  • rpf65rpf65 Posts: 1,582
    Agree, if you have room for it. Pretty big speaker.
    The other choice is the CSI A4, much smaller, less dynamic.
  • mrlorenmrloren Posts: 1,290
    CSI-A6
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S30
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • Cobragt88Cobragt88 Posts: 4
    Thanks for the advise. Next problem What AMP to power the center stage...... 250 is alot to fully drive those Rti-A5 and the CSI-A6 is power hungry as well.
    What AVR are you using? Does it have pre-out to hook up an amp? What is the main use of the system? Movies or music?
    I had a set or RTi8's with a CSI-5, same as your speakers just one model back. I was driving them with a Sony ES AVR and it did do a nice job. A friend was selling an Emotiva amp and let me try it for a few days. of yes it was nice, gave my system a more open sound. My system didn't need an amp but it sure sounded better with one.
    Depending on your AVR I would look at getting a better sub, either HSU or SVS before an amp.
    For Amp's it all about budget, new or used. For the low end Emotiva on the mid grade Parasound.
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
    Cobragt88 wrote: »
    Set all your speakers to small, cross over to the sub at 80Hz. You won't need an amp, especially in a 14' x 14' room.
    mrloren: I have a Denon AVR-X4400H it does have front center/Left Pre out plus pre out for SUB. F1nut all my speakers are set to small, do I set the crossover in the AVR or the back of the sub to 80HZ? Or both? ATM it is set to 120 LFE in AVR and same on back of SUB.
    Set the crossover in the AVR.
  • rooftop59rooftop59 Posts: 4,080
    I wouldn't even use the sub. Sorry man but my buddy had that package for years and the sub is more like a Bose bass module than a sub, it gives you almost nothing below 50 hz. I wouldn't use it personally, but if I did I would only use it for the surrounds and the .1 LFE channel.
    You have a really nice receiver that can put out about 100 WPC 5 channels driven, and those A5s aren't THAT power hungry. I would set the front three to large, unless you are going to seriously crank it. Which you shouldn't without an amp. But you can still listen at a very healthy volume running your front three full range without an amp. Check the review of the avr-x4200w, just a couple years old:
    https://www.soundandvision.com/content/denon-avr-x4200w-av-receiver-review-test-bench
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
    Yes you have a very nice AVR. Set the crossover on the AVR to 80HZ and get a good sub.
    HSU or SVS.
    An HSU VTF2 would work nice with that setup
    http://www.hsuresearch.com/products/vtf-2mk5.html
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
    mrloren wrote: »
    HSU or SVS.
    I agree that if your main goal is HT, then skip the amp for now and get a good sub. But a nice warm amp like a Parasound or B&K would make those speakers sing.
    HT Rig:
    Master Bedroom
    thanks all for the info. That AVR was on sale when i got it. rooftop59 so that's why it sounds like it bottoms out alot. LOL, i knew it wasn't the best SUB but I will replace it when I can just payed all this stuff off.. SVS 12 or 15" are alot in CAD like 1500 to 2K got alot to save up for a nice SUB.
  • tonybtonyb Posts: 28,721
    You can get a brand new SVS Sub for around 500 down here, can't believe there is that much difference. The Looney must be worth less than the Peso. :)
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
Howdy, Stranger!
