SVS SB-4000 vs. SB-16 Ultra
So I’m trying to decide between these two subs without having the opportunity to listen to them since I live in an area without any reasonable audio store. The power on both are great. The size is irrelevant to me. But after examining the SPL chart, it seems the 4000 slightly bests the 16 Ultra. I’m mostly interested in musical quality but also enjoy the low extension for electronica and rap/hip-hop as well as movies.
The app available is also a decent consideration although I realize the YPAO equalization does a reasonable.
LSIM 707s as my mains powered by an NAD M22/Yamaha 3070.
Price isn’t really an issue, I’ll probably end up with 2 of them by the end of the year anyways.
Am I missing anything? Might any of you have any input I could consider?
Thanks in advance!
I’m also open to hearing other suggestions from other companies though I’m really not trying to spend more than $2k each.
  • rpf65rpf65 Posts: 1,582
    The 16?ultra will have more head room than the 4000, or more reserve if it needs it for bass intensive material.
    Hsu and Rythmik are also very good subs at reasonable prices.
  • alucidideaalucididea Posts: 11
    edited April 14
    rpf65 wrote: »
    The Rythmic F18 looks pretty solid...
  • JaybeezJaybeez Posts: 601
    I have a Rythmik F12 SE and it's very nice with music and no slouch with HT duty. I can only imagine how much deeper that F18 would go.
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Polk PSW 350 Sub
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
  • gwhgwh Posts: 1,346
    Check Svs's scratch & dent section I picked up a 16 for $1399 delivered a few months back, one small scratch by the amp. The app is very handy for setting the phase at your listening position.
    HT:
    Polk S60
    Polk S30
    Polk F/Xi3
    SVS SB16 Ultra
    Yamaha RX-A3070
    Parasound HCA-1203A
    Signal Cable speaker wires & interconnects.
Howdy, Stranger!
