Center Channel Speaker Choice
Question: 255c-LS or 265-LS for center channel in an 11.2 setup.
Building a new home theater setup and want everything in-wall. All six (lower) channels will be 265-LS, but the center channel wall location is in a wall bay shared by a pvc pipe coming down from the upstairs floor. The width of the 255c-LS I think is two inches too wide to allow to be mounted next to the pipe when oriented horizontally.
So I have two choices - install a 255c-LS turned at 90 degrees so the longer dimension is the height. Or, just get a 7th 265-LS and use one for the center channel. Looking at the specs its hard to see if that would be a problem. My power will be at 200 watts a channel.
Suggestions?
Suggestions?
Go big and run it vertical, especially if it sits behind the screen.
Center is the most important speaker in an HT setup get the best you can and there shouldn’t be a problem mounting it vertically.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Thanks all. Ill go with the 6 265s and the 1 255 for center channel - and mount it vertically.
