Power amps — Their ohms rating
mee6
mee6 Posts: 13
Hi there,
I just got into reading about Ohms and how they relate to power amps.
However I'm still a bit confused about what to look for in an amp.
My impression is that 2 x RTI A9 will have a total impedance/load of 4 ohms.
2x RTI A9 and the CSIA6 will have total load of 2.67 Ohms.
Looking at the Parasound A 31 it can do 400 watts at a 4 ohms rating.
My impression is that if I get an A31, connect 2x A9 & a CSIA6, it will only do a maximum of 400 watts to each channel even though the total impedance is lower than 4.
Are my assumptions correct?
Thanks,
  1. Speakers
  2. center — CSi A6
  3. fronts — 2 x RTi A9
  4. rears — 2 x RTi A3
  5. Ceiling — 2x RC 80i
  6. Subwoofer — SVS PB-3000
  • Amplifiers
  • Anthem A5
  • Anthem A2
  • Marantz AV-7704
    F1nut Posts: 49,805
    edited April 2018
    Each of those speakers is an 8 ohm nominal load. Therefore, each amp channel will see an 8 ohm nominal load.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Usually most of our audio systems have one speaker connected to one amplifier channel. If we have a two speaker system each speaker will be separately connected to an amplifier channel. The same for a three or five speaker system, each speaker connected to an individual amplifier channel. It is rare that two speakers will be connected to a single amplifier, let alone three.
  • mee6
    mee6 Posts: 13
    Thanks F1nut & Kenneth.
    I see my mistake now, your explanations make more sense.
    So is my goal to match a power amplifiers watts per channel for its impedance to the speakers power capability?
    Let me know if i'm still in left field.
    1. Speakers
    2. center — CSi A6
    • Amplifiers
    • Anthem A5
    • Anthem A2
    • Marantz AV-7704
    F1nut Posts: 49,805
    Not really. You can drive a speaker rated to handle 200 watts with a 1000 wpc amp without issue 99% of the time.
    On the other hand using a 20 wpc amp to drive a speaker with a suggested minimum power rating of 50 watts will not result in the best performance. In fact, you are more likely to damage the speaker with an underpowered amp.
    Audio fact, all watts are not created equal.
    The current (amperes) rating of an amp is more important than the wpc. That spec isn't always presented, but a general rule of thumb is if the wpc rating doubles from 8 ohms to 4 ohms it's a high current amp.
  • [Deleted User]
    I believe that Parasound is a great match for Polk speakers, many satisfied owners.
  • Joey_V
    Joey_V Posts: 8,520
    I believe parasound is good, period
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    Clipdat Posts: 12,608
    Personally I wouldn't buy anything below their "JC" designated stuff.
    Joey_V wrote: »
    tonyb Posts: 32,906
    Clipdat wrote: »
    Joey_V wrote: »
    Well then you'd be missing out on some great products below that JC designation.
  • dolbyd
    dolbyd Posts: 430
    tonyb wrote: »
    Clipdat wrote: »
    Joey_V wrote: »
    Clipdat
    I agree with Tony they are a great brand.
    That being said have you checked out the new JC5. Very nice.
    http://www.parasound.com/jc5.php
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    pitdogg2 Posts: 24,582
    edited April 2018
    Clipdat wrote: »
    Joey_V wrote: »
    Coming from a guy who bought a $99 dac....
    It was actually $89.99
    I rest my case ;)
  • mee6
    mee6 Posts: 13
    Hey guys,
    Thanks for all the input.
    However seems that it got off topic a bit.
    Last thing we need is our friend ravaneli saying Emovita is better than any of your suggestions.
    I'd like to start a new thread around this idea:
    And another in terms of comparing 2 amps I have been eyeing.
    1. Speakers
    2. center — CSi A6
    • Amplifiers
    • Anthem A5
    • Anthem A2
    • Marantz AV-7704
