Jolida JD 100 Remote?
Roy Munson
Roy Munson Posts: 886
edited April 2018 in 2 Channel Audio
Hi Guys, I just unpacked my Jolida JD 100 from moth balls and to my surprise I left the batteries in the remote (which leaked all over) and it appears to be ruined. I tried cleaning it out but it's a no go..it's toast.
Does anyone know where I might be able to find a new one.
TIA
2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
    txcoastal1 Posts: 13,132
  • Roy Munson
    Yeah, I'm pretty bummed.
    Dumb move I know but stuff happens.
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    edited April 2018
    Send Walter an email....he own Underwood hifi, and a Jolida dealer
    He's great people, if he can help he will
    Call Walter Liederman at 770-667-5633 with questions
    Email- underwoodwally@aol.com
  • Roy Munson
    Thanks, I'll give him a try.
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Roy Munson wrote: »
    He may be able to give you an alternative, remote idea that carries the same signals for the jd
    F1nut Posts: 49,801
    Worse case, get a Harmony.
    Viking64 Posts: 6,686
    Roy Munson wrote: »
    Well, it sounds like you pulled a total munson on that remote. :p
  • Roy Munson
    I definitely Munsoned it!
    However I did find a solution. I contacted Jolida and they still have remotes for the JD100. Apparently the transport they now make uses the same remote. So I ordered one up. Unfortunately it's expensive at $100.00 plus shipping but I got one anyway. Problem solved.
    I won't be leaving the batteries in this one.
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Roy Munson wrote: »
    I figured you would just have them build you a new hand with a remote built right into it! :p
    I'm glad you found a solution. Now if there was just a remedy for that nasty cheese grating accident you had as a young man! :o
  • Roy Munson
    That's what I get for trying to hustle those guys back in the day.
    At least I still have my ring.
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    DSkip wrote: »
    Roy, you have a bunch of posts but I don't recognize the name. Are you a returning old timer or am I just getting less observant?
    He was in that movie King Pin duuummy
    DSkip wrote: »
    I would bet you remember his landlord. :p
    https://www.youtube.com/watch?v=W1WXMirw4D8
    Clipdat Posts: 12,602
    Whats wrong with her teeth?
  • Roy Munson
    DSkip wrote: »
    Returning old timer. lol
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
  • Roy Munson
    Viking64 wrote: »
    DSkip wrote: »
    The things I had to do. lol
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
