Panasonic RD-3100 turntable, any good?
Looking for opinions and value for this turntable?
Keith
    mhardy6647 Posts: 33,049
    edited April 2018
    If google images are to be believed :p it's a rebadged BSR. On the bright side, it will take a 1/2 inch mount cartridge (i.e., you could put a heavish-tracking MM cartridge in it) and it appears to have a metal, rather than plastic, platter.
    On the not-so-bright side, it is, to a first approximation, junk. :|
    Not complete and utter junk -- but it's on the spectrum.
  • KLapinas
    KLapinas Posts: 608
  • Msabot1
    Msabot1 Posts: 2,098
    Looks like one of those old Radio Shack LAB tables from the early 70's.....
    edited April 2018
    Msabot1 wrote: »
    Many of theirs were BSR OEM.
    The better ones were Miracords (in those days), but they were labeled as such.
    ... and "better" is relative ;)
    all three of these, e.g., are BSR-made.
    source: www.radioshackcatalogs.com (1977)
    The Miracords (and some lesser BSRs) from 1977 :)
  • verb
    verb Posts: 10,176
    Way to let a guy down easy professor! :smiley:
    I think I was very balanced and fair. ;)
    It should work and, equipped with an appropriate cartridge at appropriate tracking force, and aligned with reasonable care -- it could provide satisfactory results... but the light platter and idler drive* (especially with four decade old idler rubber) won't give that inky black background and snappy PRaT much beloved by 'audiophiles'.
    ___________________
    * Pretty sure that would be idler, and not belt drive.
  • verb
    verb Posts: 10,176
    Now that's the professor we all know and love! :smile:
  • brentkendall
    Looks like the BSR stuff was trying to copy the Dual TT's back in the day! I know that Duals are some of the best made tables out there but I just can't seem to get over that they aesthetically look like plastic toys! I know the chassis on the Duals are black metal but they just all together, along with the tone arm look like plastic junk!
  • brentkendall
    I wasn't trying to offend anyone who loves Duals, by the way ,just my humble opinion!
