What to do when your Skylan speaker stands are too short?
You make a stand riser. I talked with Noel at Skylan to see if I could just buy some longer posts for my 18 inch Skylan stands and he understandibaly explained that the labor of packing and shipping and parts costs for new posts does't make it cost effective.
I also am not married to my current listening chair and wanted some flexibility in stand height to keep the tweeters close to ear level.
I made the riser from 2 sheetsof 3/4 inch MDF glued together. I used a router to round the edges and use wood putty to seal the seam between the MDF sheets before painting. I found I still can't paint worth a crap and up close you can see brush marks, but all in all I was happy with the end result.
  • mdaudioguymdaudioguy Posts: 4,363
    Nice, simple solution, and if I saw that first pic without knowing, I would just assume that's how they were made! :)
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • pitdogg2pitdogg2 Posts: 9,838
    Or taller spikes :p
  • machonemachone Posts: 935
    Stretch'um
    Mojo Audio Joule v5>>Quantum Byte w/JRiver 21 and Fidelizer>> Starlight 7 USB >> Marantz SA 8005>> Equinox 7>>
    ModWright SWL 9.0 SE Signature >>Equinox 7>>
    Hafler DH-500 Amp+ (Musical Concepts PA-6 Elite Mod) >>Belden 5000 10 ga cables>>
    SRS 2.3TL (Fully Modified)...SDA-1A (Fully Modified with Dimensional Tweeter Delete)
    1KVA Dreadnought
  • EndersShadowEndersShadow Posts: 15,610
    Looks awesome!
  • ConradiclesConradicles Posts: 5,669
    Very nice.
  • steveinazsteveinaz Posts: 18,208
    You matched the paint perfectly, nice!
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; DH Labs D-75 | AC Power: Panamax M5300-PM
  • Jimbo18Jimbo18 Posts: 1,724
    Viagra?
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, RT25i surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
  • scubalabscubalab Posts: 2,231
    But... but... Where'd you find the black paint?
  • voltzvoltz Posts: 4,932
  • F1nutF1nut Posts: 39,620
    You need to spike the stands and would have gained the extra height by doing so.
    Tip for painting, Krylon rattle can.
  • pumpkinmanpumpkinman Posts: 5,912
    Looks great problem solved
    Because I am The Pumpkinking
  • Polkitup2Polkitup2 Posts: 1,408
    edited April 14
    Hard to tell from photo but the stands are already spiked (thick carpet and pad). I tried to find taller spikes but didn't find anything substantially taller - thus the risers.
    What actually happened is that I started with spray paint which worked great on the top, but not so good on the edges. On the edges where I had applied wood sealer to cover the seam between boards, I did not cover the entire edge with sealer and the paint was absorbed by the MDF and required a second, and a third coat. Even when it dried overnight the edges still looked blotchy. I then decided to sand it all down and start fresh using the brush.
    Live and learn, next time when working with MDF I will completely seal the edges prior to painting and go with the rattle can.
    scubalab wrote: »
    Very difficult, I had to special order because they did not have the black I was looking for. They just had regular black. I was looking for extra black paint.
  • verbverb Posts: 2,570
    Nice job! How did you attach the risers to the stands?
    2CH: Polk SDA 1C's, Micro Seiki MB14 TT, Rotel 1580 Pre, Marantz CD6006 CDP, Carver TX8 Tuner, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    I used the same thing between the riser and the stand as between the riser and speaker. 3M makes these non-staining things called bumpons which have an amazing hold on anything that sits on them.
    https://www.amazon.com/gp/product/B06Y1TMJZH/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    Thanks for the info! I was wondering also if you primed the surfaces before shooting the color? A few coats of primer usually takes care of the absorptive rates of different materials.
    The spray paint was a combo primo and paint in one can. As a matter of fact it also claimed to contain 2 cans worth of paint in one can. No wonder it didn't work well, too much going on in one can of paint!
    Polkitup2 wrote: »
    For future reference, take a look at Adona Multi-Element cones, which are 2.5" tall.
    Thanks for the tip, I will check those out.
Howdy, Stranger!
