Should I return my Signa S1 if the optical cable does not produce red light?
I purchased a new Signa S1 sound bar and correctly connected everything with my Sony Bravia television. I see red light emitted from the optical cable when connected to the TV, but there is no light from the cable when connected to the soundbar with the power on and optical cable selected as input. It plays via bluetooth and also will play with the AUX connection, but my AUX connection is actually a headphone connection and it reduces certain settings when you utilize that plug. Thanks for your help.
Answers
  • mlistens03mlistens03 Posts: 1,189
    If I understand your question correctly, when the cord is plugged in to the tv you can see the red light on the other side, but not the same when it’s plugged into the soundbar?
    I believe that the soundbar shouldn’t actually produce any light as it is receiving the signal and not sending it.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • SugarmillManSugarmillMan Posts: 175
    I would like to know the answer to this, as well. Anyone else have a thought?
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • DaveHoDaveHo Posts: 1,824
    You'll only get light from the optical cable when it's connected to a source. The soundbar is NOT a source.
  • shelbyhshelbyh Posts: 3
    SugarmillMan, thanks I agree, so any insight as to why it would not produce sound if I see light on the far end when connected to my TV? Wondering if I need to return it as the receiving portion of the soundbar may be failing I gather. Thoughts?
  • nguyendotnguyendot Posts: 3,583
    Did you plug the receiving end of the cable into another device that did produce sound?
    Main Surround -
    This is actually my only optical connection device in my house
Howdy, Stranger!
